Smokstak Down Under
Another one in the Pipeline
this thread has 24 replies and has been viewed 1816 times
Old 07-30-2018, 02:24:01 AM
Darryl Darryl is offline
Default Another one in the Pipeline
Trying to get hold of this one.
The Following 3 Users Say Thank You to Darryl For This Post:
Old 07-30-2018, 02:27:10 AM
Default Re: Another one in the pipeline
Pretty ugly bugger
Old 07-30-2018, 02:30:36 AM
Direct coupled to a 10" Thompsons pump .
Old 07-30-2018, 02:36:25 AM
Was originally on the Murray River but shifted twenty odd years ago to a reuse system.
Was just picked up in one unit, concrete and all and placed here.
Old 07-30-2018, 02:40:37 AM
26hp at 700 rpm Blackstone.
The Following User Says Thank You to Darryl For This Post:
Old 07-30-2018, 05:19:00 AM
Lanzb Lanzb is offline
Default Re: Another one in the Pipeline
I got a 16 hp one of those, it's a real nice running engine, worth collecting for sure.
The Following User Says Thank You to Lanzb For This Post:
Old 07-30-2018, 06:47:43 AM
Hi simon, ya haven't got it on YouTube.
Old 07-30-2018, 07:36:03 AM
Haven't had it long enough!
Old 07-30-2018, 08:37:40 AM
Nathan Woodruff Nathan Woodruff is offline
Ripper set up, Would look great at your place Darryl.
The Following User Says Thank You to Nathan Woodruff For This Post:
Old 07-30-2018, 09:42:24 AM
Peter Short Peter Short is offline
Darryl,
Here are some specs for Blackstone Horizontal Engines from 1954, 1957 & 1965 catalogues. Do you think this is the same model?
Click on the image 3 times to get maximum size. Let me know if you want better resolution images.
Name:	Blackstone 1954 specs part 1.jpg
ID:	315266   Click image for larger version
Name:	Blackstone 1954 specs part 2.jpg
ID:	315267   Click image for larger version
Name:	Blackstone 1957 specs.jpg
ID:	315268   Click image for larger version
Name:	Blackstone 1965 specs.jpg
The Following 2 Users Say Thank You to Peter Short For This Post:
Old 07-30-2018, 04:56:47 PM
Paul Richardson Paul Richardson is offline
The Thompson Pump is a good size Darryl.The last I saw any of their stuff being produced it was Billmans at Castlemaine who were casting impellers and housings for them,about 10 years ago?..15 years,.? If I have it right Thompsons foundry is closed now?
What are your thoughts on moving this time if you manage to acquire it Darryl?The whole shooting match again in one blob,concrete and all?
Old 07-30-2018, 05:21:06 PM
Not sure about this but wasnt Thompsons also casting for Kelly and Lewis ? I think i rang Thompsons about a new impeller once for a 12" K and L years ago.
Also Paul, about moving it, im not sure. Initial investigations (8 or 9 years ago) ended with "we're going to use it one day" but they never did.
One of my angles now is to install a "newer" engine to drive the pump so i only get the engine.
I am on a loosing streak lately ( spring injection Blackstone) so i'll see what happens.
Old 07-31-2018, 01:47:01 AM
Originally Posted by Peter Short View Post
Darryl,
Jeez thanks Peter, i only just spotted this. This engine is the OP size. Some interesting info there , thanks again.
Old 07-31-2018, 02:12:59 AM
cobbadog cobbadog is offline
Great find Darryl,
Did it come with the extra fuel tank standing behind the engine?
Look forward to hearing it run.
Old 07-31-2018, 04:01:55 AM
Nah, fuel tank will stay there because I'll probably set up a Chinese twin cylinder there to drive the pump but I'll have to do some sums because i had another look today and the Thompson pump is actualy a 12".
Thats if i crunch the deal !
Old 08-01-2018, 01:35:30 AM
Craig Gillingham Craig Gillingham is offline
I've got a vague feeling I remember this engine, it was North of Cohuna? I remember going to the farm in the early 90's with my father, and at that time, the Blackstone was still in use, if it's the same one?
Old 08-01-2018, 04:20:38 AM
No Craig, i know that one because i work on it. I installed a honda starter motor setup on it some years ago and ive also converted it to vee belts instead of the flat belt.That family is the Franz family who have still got there steam engine and some brand of 1920's car that is the only one in the world from France or something.
Do you know them Craig ?
Also, they still use it.
Old 08-01-2018, 06:00:33 AM
Darryl,
Just wondering - what are the vee belts for?
Old 08-01-2018, 06:56:09 AM
To run a large irrigation pump. The flat belt was about 20 foot between pulleys but they put in a new Chinese pump alot closer and drove it with vee belts instead.
Old 08-01-2018, 09:07:05 PM
Darryl, that sounds like the same family. I don't know them, but dad did and we went there to buy something or pick something up, I can't remember what it was. Another thing they had there was a Blitz truck (not sure if it was a Ford or Chev) that they still used to cart cattle, and at the time it was the oldest truck still on full rego in Victoria.
Lincoln 200 Pipeline Welder Fred-E Welding Shop 6 12-14-2005 10:24:12 PM
