Smokstak Down Under
Delco 600W Light Plant Oil Capacity
this thread has 12 replies and has been viewed 967 times
Old 08-17-2018, 08:29:54 AM
Jonesey Jonesey is offline
Default Delco 600W Light Plant Oil Capacity
I’ve just acquired a Delco 600W Farm Lighting plant, after start up it gets to much Oil blow by into the combustion and over board with leakage. I suspect the oil level is way to high as it’s upto the top of the fill screw cap. Does anyone know the level height that it should have or the capacity of the tank, so I can drain and refill with the correct level.
Many Thks Les
ID:	316444   Click image for larger version
ID:	316445   Click image for larger version
The Following 2 Users Say Thank You to Jonesey For This Post:
Old 08-17-2018, 11:30:47 AM
jayvee jayvee is offline
Default Re: Delco 600W Light plant oil capacity
Jonesey,
Somewhere on your engine there should be an indicator that would tell you when the oil level is full.
Having said that, the good book says,
"At the end of almost twenty hours of running, remove the filling plug, or look at the oil indicator. Add oil until it shows in the filling hole, or until the indicator shows FULL. This should always be done before starting the engine."
"If Plant throws oil:-
1. Gaskets may be blown out. Make sure oil does not come from the base of the cylinder head, base of cylinder or from around the cover plate. Inserting an extra gasket will eliminate oil leaking from crevices.
2. Felt washers in bearing housings may be worn. (applies to plants below #14395) Replace with fibre washers, also stop up drain hole with fibre plug.
3. Valve plungers may be pumping oil. Clean out hole in bottom of valve plungers and slot in push rods; then fill valve plungers with good grade felt.
4. There may be a sand hole in castings. A small sand hole may be stopped up with iron cement.
5. Crank case may be porous. Clean inside of crank case thoroughly and paint with a good filler, such as white lead.
6. Intake Breather Valve not working properly."
Hope this is of some help. Good luck
Best wishes, jayvee
Last edited by jayvee; 08-17-2018 at 11:41:22 AM. Reason: Grammar + one too many digits in engine #
The Following 3 Users Say Thank You to jayvee For This Post:
Old 08-17-2018, 05:19:47 PM
Scotty 2 Scotty 2 is offline
Default Re: Delco 600W Light Plant Oil Capacity
Hello all
That is a really nice display. I like the glass battery inclusion. You don't see that very often.
Cheers Scott
The Following 2 Users Say Thank You to Scotty 2 For This Post:
Old 08-18-2018, 12:02:46 AM
Darryl Darryl is offline
Id say Jayvee's no.6 is the cause . Crankcase breather.
The Following User Says Thank You to Darryl For This Post:
Old 08-18-2018, 04:25:02 AM
Thanks Jayvee, unfortunately the level indicator doesn’t work as it points to half full and the level is upto the top of the fill cap. There appears to be to much oil on top of the piston and spark plug as well as weaping around the base of the induction tube through the cork gasket. I will replace the cork but uncertain if the oil in the cylinder is either a cylinder ring problem or oil level to high, so I will drain crankcase and refill if I can determine what capacity it holds.
In regard to item 3 and 6 in your response, can’t locate any crankcase breather valve or the valve plunger, is that the intake/exhaust valve ?
Thks Les
---------- Post added at 04:25:02 PM ---------- Previous post was at 04:18:18 PM ----------
Thanks Scotty, yes the glass batteries are hard to find, I will run a 32V drill and fan if I can get the engine to run properly and fix the oil problem. The engine is not that smooth.
Rgds Les
Old 08-18-2018, 06:10:49 AM
Brock Summerfield Brock Summerfield is offline
Email NOT Working
In the first picture there is a vertical plug with a pin going through it ,, I would guess that is the level plug and filler .
The Following User Says Thank You to Brock Summerfield For This Post:
Old 08-18-2018, 04:22:29 PM
What is the tall cylinder looking thing with the brown top and the pipe coming and out heading down?
And also the dipper switch looking gismo to the left of it?
At a rough guess, I'll have a bet there's a breather in one of those. My better guess is at the base of that tall tube.
Cheers Scott
The Following User Says Thank You to Scotty 2 For This Post:
Old 08-19-2018, 04:42:49 AM
Yes Brock that is the oil fill cap but it doesn’t have a dip stick. Thks Les
---------- Post added at 04:42:49 PM ---------- Previous post was at 04:36:36 PM ----------
Scotty that is the induction pipe with the fuel/air metering valve on top. The engine has a positive crankcase ventilation system, that is the air inlet is via the crankcase. Saying that it does have a small hole half way up the tube but not much oil coming out of the hole.
Rgds Les
Old 08-19-2018, 08:42:35 AM
rodneyt rodneyt is offline
the motor having a very low down fill plug, would seem to be impossible to overfill to the extent of causing a problem?
curious to know what exact type of oil is being used?
"air inlet is via the crankcase"
possibly if a multigrade is being used, it might be too thin, allowing it to form fine splash particles in the air which get "consumed'? remember that multigrade oils are made from the lower grade base oil, then the multigrade additive is added until the desired high grade viscosity is achieved at the high temperature rating. at all times the actual oil itself is always the lower grade thinner oil. the multigrade features have amazing benefits for car engine lubrication, but could well do nothing to stop a thin oil from forming small particles? .... cheers Rod.
The Following User Says Thank You to rodneyt For This Post:
Old 08-19-2018, 10:08:25 AM
I’m not sure of the grade oil, as I’ve just odtained it from another collector. I plan to drain it tomorrow as I found out the capacity which is 3 pints or 1.4 litres and that will give me a guide to see if it was over full. I will refill it with 30 grade for stationary engines and see if that fixes the problem.
Thks Les
The Following User Says Thank You to Jonesey For This Post:
Old 08-21-2018, 02:29:05 AM
cobbadog cobbadog is offline
Hi Jonesey,
A while ago you sent me a couple of PM's about B model Mack parts and a SP1 McDonald engine. I replied but haven't heard back on either. Do you still have access to them?
Old 08-21-2018, 05:18:32 AM
Hi Cobbadog
You’ve got me with that query, can you refresh my mind as I don’t remember. How long ago was it ?
Rgds Les
Old 08-22-2018, 12:39:26 AM
It was about 12 months back when you asked if my mate was still after the McDonald and as it happened the same bloke was interested in the B model Mack parts as well.
I will have a look in the PM department to see if I still have them. Cheers
Delco 850 light plant scottmumaw Delco and other Low Voltage DC Light Plants 3 06-14-2017 03:42:09 PM
Delco Light 32V 600W Information NFellows Delco and other Low Voltage DC Light Plants 13 12-19-2009 11:48:29 AM
Delco light plant Mike in CA Delco and other Low Voltage DC Light Plants 1 01-29-2009 12:51:40 AM
Delco light plant Graham Jones Delco and other Low Voltage DC Light Plants 3 10-17-2003 12:11:54 PM
