Smokstak Down Under
Sunshine Kerosene Engines
this thread has 14 replies and has been viewed 1318 times
Old 08-19-2018, 06:55:02 AM
typak typak is online now
Default Sunshine Kerosene Engines
I acquired this Kerosene Sunshine 7hp the other day for the carburetor and manifold for a petrol Sunshine I'm working on, at a glance they appear to be the same? only difference I can see are the two screws on the cylinder above the intake port? what differences between the Petrol and Kerosene versions ?...
ID:	316586   Click image for larger version
ID:	316587   Click image for larger version
ID:	316588   Click image for larger version
Old 08-19-2018, 07:19:18 AM
lanzalldog lanzalldog is offline
Default Re: Sunshine Kerosene Engines
Hi Typak,
Are the screws there to hold in the gauze in the intake port?
The only difference I can see is a stud hole or casting mark near the air intake on the front of the carb.everything else looks the same
The Following User Says Thank You to lanzalldog For This Post:
Old 08-19-2018, 09:20:35 AM
Mick's Avatar
Mick Mick is offline
Why u call it a kerosene sunshine typac? I know what the difference is between a petrol and kero one. Did the seller tell u that and did u get all the brass bits for it too?
The 2 screws are there just to locate the gauze
Old 08-19-2018, 08:30:30 PM
Scotty 2 Scotty 2 is offline
That should have a little elbow on it to pour some fuel into the bowl to have fuel to start. It takes a couple of seconds for the pump to get fuel up to there.
Cheers Scott
The Following User Says Thank You to Scotty 2 For This Post:
Old 08-20-2018, 06:41:47 AM
Winchester Winchester is offline
Is that a ten HP version Tim?
---------- Post added at 06:41:47 PM ---------- Previous post was at 06:39:57 PM ----------
Sorry yes you said 7 HP, from memory mine is a five HP .
Old 08-20-2018, 07:11:57 AM
sunshineman sunshineman is offline
Who is tim
Sunshineman
Old 08-20-2018, 04:44:07 PM
Originally Posted by sunshineman View Post
Who is tim
Sunshineman
Is he this Tim? Often seen holding his bit and admiring it.
Old 08-20-2018, 07:12:54 PM
Hi scotty
Winchester must have had a scotch before posting
Sunshineman
Old 08-21-2018, 12:37:37 AM
Yes well Tim , perhaps there were Kero versions of the Sunshine Two stroke engines . They no doubt would have had a supplementary fuel tank,gravity feed
and a stop cock to isolate the base tank......or am I '' Barking up the wrong tree?''
My 7 HP version does not have the two brass screws as you depicted in your initial post
---------- Post added at 12:37:37 PM ---------- Previous post was at 12:29:13 PM ----------
Hi scotty
Sunshineman
Yes well I thought I would devote a few moments to respond to this silly post by Sunshineman. In the past he has posted very informative ,replies and answers to questions posed by others . It is a shame that he now has resorted to a silly reply that is neither clever nor original.
Old 08-21-2018, 03:43:49 AM
So the Tim in the picture is the same Tim your talking about Mr Goose?
Is it a new nickname for Typak? The Toooolman.
Old 08-21-2018, 05:24:46 AM
Winchester, from my understanding they had a brass starting tank in place of the regular priming cup on top of the carburetor, the starting tank being of about 1/3 pint capacity? I would think they would run quite satisfactorily on Kerosene fuel after the initial warm up, I have had little experience with Sunshine engines and may need a expert on Sunshine two strokes for this project, image from the interweb of a Kerosene Sunshine?
Old 08-21-2018, 06:27:19 AM
Darryl Darryl is offline
Mine's got that little tank for a primer but ive never heard of a Sunshine being run on kero. I think its just a bit more handy having the little tank as you dont need to find any petrol for a priming cup.
( and i have had a scotch )
Old 08-21-2018, 05:10:43 PM
Hello all.
I only had a cup of warm Milo before bed last night.
I remember reading some of Mr Sunshine's posts and there's another difference between the two versions Kim Tim the Toooolman.
Cheers Scott
Old 08-21-2018, 08:37:00 PM
Well Scott you obviously mean the trough in the port for catching unvaporized Kerosene, as for differences in Sunshine engines there are quite a few from square crankcases to flyball governors being the most obvious, none of this really relevant as the carburetor is for a petrol engine for starting the Crossley in my gold battery, no doubt I will find the original carburetor amongst the junk after fitting the replacement.
Old 08-21-2018, 11:15:02 PM
If you know it all then why did you ask Kim Tim the Tooolman?
Cheers Scott
Cooler Tanks for Sunshine 2 Stroke Engines john gilbert Smokstak Down Under 8 06-15-2018 08:22:40 PM
sunshine 2 stroke engines sunshineman Smokstak Down Under 12 03-26-2016 01:54:38 AM
Engines Out for a Little Sunshine Skip Landis Hit & Miss Gas Engine Discussion 20 05-18-2012 02:59:54 PM
Any Rawleigh Kerosene Engines ? Michael E. McCracken Hit & Miss Gas Engine Discussion 2 09-27-2011 03:20:05 PM
Wintering engines in the Sunshine State Jeff Smith Steam Stationary Engines, Traction Engines 8 10-28-2006 10:27:53 PM
