Smokstak Down Under
OLDS 1A Fuel Pump
this thread has 2 replies and has been viewed 483 times
Old 08-19-2018, 03:03:50 PM
Gary Moss Gary Moss is offline
Default OLDS 1A Fuel Pump
Howdy all anyone down under making repro fuel pumps for the OLDS 1A ENGINES
Old 08-19-2018, 05:17:27 PM
Darryl Darryl is online now
Default Re: OLDS 1A Fuel Pump
There was some Olds parts on ebay a while ago. You could chase that lead down if the parts are still on there.
The Following User Says Thank You to Darryl For This Post:
Old 08-19-2018, 06:57:25 PM
Luke Luke is offline
Olds 1A engines do not have fuel pumps, they rely on suction to lift fuel to the mixer. That engine seems to have a home made mixer rigged up on it. The fuel tank is usually located in the base, see the filler hole or drain hole in the side of the base, and the fuel outlet protrudes through another hole in the front of the base where there is a one way check valve. See pic attached for general layout
The Following 3 Users Say Thank You to Luke For This Post:
Olds 1A Fuel Pump Gary Moss Hit & Miss Gas Engine Discussion 10 09-01-2018 06:08:20 PM
OLDS - OLDS - OLDS Engines (1890-1919). Denis Rouleau Hit & Miss Gas Engine Discussion 47 01-23-2017 05:37:08 PM
Seager (Olds) 2A Fuel mixer, anybody make a reproduction. Will Batty Hit & Miss Gas Engine Discussion 7 09-20-2012 12:46:31 PM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
Olds 4A fuel system help JECaton Hit & Miss Gas Engine Discussion 2 09-30-2005 11:29:45 AM
