Smokstak Down Under
Southern Cross Farm Pump Engine
this thread has 23 replies and has been viewed 1755 times
Old 09-07-2018, 02:11:26 AM
Scotty 2 Scotty 2 is offline
Default Re: Southern Cross Farm Pump Engine
Originally Posted by Burrows75 View Post
The attached photo is a magneto I have from another pumper, would it be correct for a 1944? I think not due to the additional aluminium brackets.
Thanks Adam
Read post #16.
Old 09-07-2018, 05:03:51 AM
Rusty Engines Rusty Engines is offline
eMail NOT Working
**25649 and 22919, flywheels only, found at Toowoomba Swap Meet.**
25649 year 1947
22919 year 1946
Ian
---------- Post added at 07:03:51 PM ---------- Previous post was at 06:54:08 PM ----------
Lucas magneto for engines
from 8413 to 24213
Ian
The Following User Says Thank You to Rusty Engines For This Post:
  #23
Old 09-07-2018, 04:00:12 PM
from 8413 to 24213
Ian
It wouldn't be a Lucas NIL with clockwise rotation by any chance Ian?
Cheers Scott
Old 09-16-2018, 03:02:54 AM
Burrows75 Burrows75 is offline
Hi All,
Had some time and decided to work on the farm pumper.
The gibb key came out fairly easy. The crank is damaged from lack of grease but with another front housing and a good bearing pressed into place there is very little movement. The crank is stamped with the same engine number so I was hoping to save it without major expense.
Still need another magneto as the one fitted is not correct and even though it is running it is a poor fit held on with one bolt. I am working on the crank case door.
It's a bit smoky as I was running the oiler a bit quick. Needs a little bit more tinkering but at least it is running again.
https://youtu.be/3Ob50wbfMgw
Adam
The Following User Says Thank You to Burrows75 For This Post:
Southern Cross Farm Pumper... albeit a lowly SC Winchester Smokstak Down Under 7 11-15-2016 01:20:00 AM
Southern Cross Farm Pumper- eBay parts. muzzery Smokstak Down Under 1 06-20-2016 04:54:50 PM
Southern cross farm pumper main bearing timc83 Smokstak Down Under 12 08-23-2014 01:35:42 AM
Buzacott/Southern Cross Farm Pumper Parts gozoish951 Smokstak Down Under 0 04-06-2014 04:38:06 AM
Southern cross farm pumper parts wanted Ian Long Smokstak Down Under 5 04-06-2014 04:34:42 AM
