Magneto application
this thread has 4 replies and has been viewed 771 times
Old 03-25-2019, 06:40:45 PM
Lonnie Grissom Lonnie Grissom is offline
Default Magneto application
What would a splitendolft s 2 magneto be used on old tractor, motorcycle,engine, etc. i have one and can't find enough in fo on computer. Thanks if anyone can educate me. It is base mounted. Coupled driven and two cylinder. I'm trying to learn how to post pictures.
Old 03-27-2019, 12:32:02 AM
Craig Gillingham Craig Gillingham is offline
Default Re: Magneto application
The S2's were most commonly used on Indian motorcycles, 1922-27. They were also used on Excelsiors as well, and there was a vertical twin stationary engine that also used the S2. The problem is they were all for different applications, Indian 42°, Excelsior 45°, the stationary engine 180°, CW, CCW, etc. If it's still got the brass plates on the sides with the four digit application number, you may be able to tell what it suits from that. I have got a listing I can look up, if it helps. The application number will look something like in this photo.
Name:	DSC07154 - Copy.JPG
Old 03-27-2019, 11:31:35 PM
ulgydog56's Avatar
sounds like you may have some money there....try to post a pic...
Old 03-29-2019, 10:22:59 PM
Craig the numbers are s2---1664 . I don't know if it is cw or ccw. It turns both ways. Ulgydog56 as soon as I can slow a grandchild down may they can teach me how to post pictures. Thanks to both of you for the info.
Old 04-01-2019, 06:25:39 PM
I found the references I was looking for online. It says a 1664 is for a Le Roi, CW 180° twin with a fixed spark (no advance?) and possibly has an impulse drive? I'm not familiar with these engines, someone may be able to tell you more?
http://www.splitdorfreg.com/Splitdor...tdorf-Apps.htm
FM type R Magneto Application Firewoodguy Magnetos, Ignition Coils and Spark Plugs 2 07-11-2018 11:26:35 AM
what is the application of this magneto? Charlie Mc Magnetos, Ignition Coils and Spark Plugs 1 11-08-2012 07:32:22 PM
Sumter Magneto Application Frank Gassett Hit & Miss Gas Engine Discussion 0 08-16-2007 08:12:19 PM
Bosch magneto application KidDynamo Hit & Miss Gas Engine Discussion 1 07-21-2006 04:36:23 PM
Magneto Application jerry larner Antique Engine Archives 0 11-12-2003 09:16:10 AM
