Welding Shop
Forney 180 Welder/Reverse Polarity Rods
this thread has 2 replies and has been viewed 351 times
Old 06-09-2019, 07:52:54 PM
Kevin G Kevin G is offline
Default Forney 180 Welder/Reverse Polarity Rods
First of all I'm not a professional welder but have done some TIG /tool steel welding back in my Tool & Die, Mouldmaker days. Have run a Lincoln 225 AC forever in my home shop with good results using 6013 & 7014. Recently came across an old Forney 180 welder with the plug in leads. Has anyone run 7018 DC reverse polarity rods on a welder like this? I know it's still an AC welder but would the leads being reversed allow me to run this rod? Also know there's a 7018 AC rod available but I have a source for the DC rods. TIA.
Old 06-09-2019, 08:26:41 PM
DustyBar DustyBar is offline
Default Re: Forney 180 Welder/Reverse Polarity Rods
Sorry, changing the plugs won't reverse the polarity because its still AC.
Old 06-09-2019, 11:32:34 PM
Heins Heins is offline
Most AC welders won't push 7018 rod, they have 7018 AC rod but I'm not a fan of it.
Champion generator 3500/4000 reverse polarity johnrm57 Generac Generators (SEARS, etc.) 4 09-09-2015 10:14:45 PM
Forney Welder + Genset Problems... Burt Lade Welding Shop 1 11-07-2013 06:33:35 PM
Forney Welder model C-6BT questions Josh Stone Welding Shop 3 12-18-2011 10:15:33 AM
Polarity Reverse part II George Vaughan Magnetos, Ignition Coils and Spark Plugs 6 07-30-2008 12:06:02 PM
Polarity reverse George Vaughan Magnetos, Ignition Coils and Spark Plugs 4 07-10-2008 10:07:35 PM
