"Manitoba" Engine
this thread has 14 replies and has been viewed 1396 times
Old 07-23-2019, 03:27:24 PM
beechcraft1 beechcraft1 is offline
Default "Manitoba" Engine
I've just restored and have running a 1916 Manitoba 7 HP engine and am looking for any publishings,info, photos, stories,other engines,etc. that anyone can supply. It's got a Bosch Type 22 mag, dual stage cam timing, starts and runs like a clock. Came with a badly bent crank, straightened it and runs true as could be.
John
The Following 3 Users Say Thank You to beechcraft1 For This Post:
Old 07-23-2019, 04:09:43 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Re: "Manitoba" Engine
Show us pictures of what you have.
Denis Rouleau
Old 07-24-2019, 05:08:29 AM
Malcolm Robinson Malcolm Robinson is offline
Is this the engine you have been working on John? I know it was in your area for many years before being sold in 2015.
I owned a 1 1/2 HP Manitoba here in England several years ago.
Malcolm.
Name:	Canada 2015 214.jpg
ID:	339804   Click image for larger version
Name:	Canada 2015 215.jpg
The Following 5 Users Say Thank You to Malcolm Robinson For This Post:
Old 07-24-2019, 07:59:51 AM
Kevin A. Behnke Kevin A. Behnke is offline
I see that Manitoba liked to copy others designs. Looks a lot like a John Lauson and I know others copied Monitor engines.
The Following 2 Users Say Thank You to Kevin A. Behnke For This Post:
Old 07-24-2019, 11:32:01 AM
Rudy Rudy is offline
Malcolm.
Hi Malcolm. That engine looks like the one that belonged to our good friend ,Lorne Radcliffe from Cardale ,MB ?
Rudy Adrian
The Following 2 Users Say Thank You to Rudy For This Post:
Old 07-24-2019, 05:45:23 PM
Bryan Storey Bryan Storey is offline
I have an 8hp in the shop right now that I just got running. Looks just like yours but mine is igniter fired with no place for a magneto. Battery and coil only.
Like to say thank you to Rudy Adrian for sending me blueprints for the igniter and igniter trip parts.
ID:	339906   Click image for larger version
ID:	339907   Click image for larger version
ID:	339908   Click image for larger version
The Following 6 Users Say Thank You to Bryan Storey For This Post:
Old 07-25-2019, 08:06:40 AM
Good to hear from you Rudy, yes your correct in every way, good friends mean a lot in this world.
Malcolm.
The Following User Says Thank You to Malcolm Robinson For This Post:
Old 07-25-2019, 09:39:27 AM
Originally Posted by beechcraft1 View Post
I've just restored and have running a 1916 Manitoba 7 HP engine and am looking for any publishings,info, photos, stories,other engines, etc. John
If the name tag has the name "Manitoba Wind Mill & Pump Co. on it the engine was built prior to September 1912. In September 1912 the company name became "Manitoba Engines Ltd.".
Denis Rouleau
The Following 2 Users Say Thank You to Denis Rouleau For This Post:
Old 07-25-2019, 09:46:54 AM
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
Old 07-28-2019, 09:46:49 AM
Finally managed to get out out to the hanger and get some pics for you guys. Thanks for any and all help and advice. From what I found out so far sounds like this engine went on an auction in Saskatchewan somewhere. But I stand to be corrected.
John
ID:	340191   Click image for larger version
ID:	340192   Click image for larger version
ID:	340193   Click image for larger version
The Following 4 Users Say Thank You to beechcraft1 For This Post:
Old 07-28-2019, 09:50:21 AM
Forgot to ad that I have a few details left to finish or change but at least she runs. Tank is a Leseure find,spark plug wire is just till I get an original style and so on.
John
Old 09-20-2019, 03:13:50 PM
Here's the serial number plate for my Manitoba. Guess it was a later one.
John
ID:	344497   Click image for larger version
Old 09-25-2019, 08:51:04 AM
Captain K Captain K is offline
Hello
I too have a Manitoba engine. No name plate. Has Manitoba Horse cast in raised letters on the hopper. It's missing the igniter and mag and some other stuff. Crank is bent pretty bad at main journal. How do people straighten them? Flywheels off and press was my thought. Worried about getting flywheels tight again. Rudy, do you still have drawings for the igniter etc.?
Kirk
The Following User Says Thank You to Captain K For This Post:
Old 09-25-2019, 11:47:58 AM
Mine is spark plug and mag fired, works great. My crank was badly bent at both main journals and so I took off flywheels to press straight. Runs dead true now. Had no problem with getting flywheels tight with reusing the old gib keys.
John
The Following User Says Thank You to beechcraft1 For This Post:
Old 09-25-2019, 09:17:53 PM
Kyle McGee's Avatar
Kyle McGee Kyle McGee is offline
Kirk
I had an engine I was working on with a bent crank and I was doing research on smokestack on how to straiten it, there was a post where someone had commented "the crank got bent in the engine cold it can be bent back in the engine and cold". that saying stuck with me and I built up a little jig to mount the engine down and I used a jack and made cup out of angle iron to sit on the crank and mounted a magnetic dial indicator on the hopper and found the highest spot out and put it at the top and jacked it up. did it a couple times and spun the flywheels each time to find where it still needed bent and now its true as true can be and have had no issues.
hopefully this helps,
The Following User Says Thank You to Kyle McGee For This Post:
"GM" DD 6-71 Engine help and questions on a marine keel cooled "GM" DD 6-71 svUbiquitous Antique Marine Engines and Outboard Motors 8 11-07-2016 12:23:15 PM
Fairbanks-Morris "Z" Engine Style "D" 1-1/2 hp. Steve Webre Farm Antiques and Collectibles 0 10-11-2016 09:23:47 PM
Need Cont'l Engine Book Help Re' "N", "NA", "N-NA" Engine Confusion 1915-25 Bud Tierney Antique Autos and Trucks 0 11-06-2015 04:04:38 PM
"Flea Market" engine 3HP "Z" Sam Harman Hit & Miss Gas Engine Discussion 9 09-23-2010 12:22:26 PM
Was there an "Original Cart" for a FM "Z" engine? DerekC Hit & Miss Gas Engine Discussion 4 11-08-2007 11:10:01 PM
