Smokstak Down Under
Funeral Home Sunshine
this thread has 12 replies and has been viewed 1167 times
Old 07-30-2019, 09:59:14 AM
typak typak is offline
Default Funeral Home Sunshine
Picked up this little engine today after chasing it for years, was a stand by engine from a funeral home and has done very few hours also has the original Mea magneto that's seldom seen nowadays, should start right up with a little fuel and a spin of the flywheels .....
ID:	340354   Click image for larger version
ID:	340355   Click image for larger version
ID:	340356   Click image for larger version
The Following 12 Users Say Thank You to typak For This Post:
Old 07-30-2019, 10:01:47 AM
Default Re: Funeral Home Sunshine
A few more pics..
ID:	340359   Click image for larger version
ID:	340360   Click image for larger version
The Following 6 Users Say Thank You to typak For This Post:
Old 07-30-2019, 01:17:13 PM
Vanman Vanman is offline
That's NEAT!
What did it used to power? A generator? I presume that was gone already?
Keith
Old 07-30-2019, 01:55:48 PM
Nice find!
Old 07-30-2019, 05:27:29 PM
Darryl Darryl is offline
Nice engine, it probably supplied a steady supply for the funeral home with people trying to start it and having heart attacks.
The Following 4 Users Say Thank You to Darryl For This Post:
Old 07-30-2019, 05:41:05 PM
john gilbert john gilbert is offline
Hey Daryl, you just gave me a good laugh. cheers, John
The Following User Says Thank You to john gilbert For This Post:
Old 07-30-2019, 09:41:19 PM
Your not wrong, the 10hp are a handful when pulling over for starting, the magneto needs to be perfect or your wasting your time, the late Ivan Brown rewound the Mea years ago and it was never refitted and engine started by the previous owner, also the half compression tap is there for a reason and should be definitely opened for starting!
---------- Post added at 12:41:19 PM ---------- Previous post was at 12:33:55 PM ----------
Originally Posted by Vanman View Post
That's NEAT!
Keith
In my understanding refrigeration plant that's long gone to the scrap yard, at least the engine was saved.
The Following 3 Users Say Thank You to typak For This Post:
Old 07-30-2019, 10:11:21 PM
Paul Richardson Paul Richardson is offline
Not to take away from that nice Sunshine engine Kim,..but the question that must be asked would relate to the other item seen loitering in the background.The four post 'elephant in the room'?
I'm guessing of course but ,..?..Frisco Standard!?,..or similar,not quite complete?
Do you always go out to retrieve your Sunshine engines with one of those on board for a greeting party?Wondering what's the story on that other very interesting engine?
The Following User Says Thank You to Paul Richardson For This Post:
Old 07-30-2019, 10:23:47 PM
DustyBar DustyBar is offline
Originally Posted by Paul Richardson View Post
...Do you always go out to retrieve your Sunshine engines with one of those on board for a greeting party?...
Might need bait. You just never know.
The Following 2 Users Say Thank You to DustyBar For This Post:
Old 07-31-2019, 01:19:20 AM
Just picking up that SF Standard as I had it stored where the Sunshine was and take it home as I have another 4hp in real nice condition that has the igniter missing and will make a copy, the igniter as shown is a little on the sketchy side and needs a bit of wrenching like the rest of this engine, another project for another day....or two?
ID:	340412   Click image for larger version
ID:	340413   Click image for larger version
ID:	340414   Click image for larger version
The Following 2 Users Say Thank You to typak For This Post:
Old 07-31-2019, 07:03:39 AM
Winchester Winchester is offline
That's NEAT!
Keith
Yes well in my opinion it was no doubt used to drive an ammonia compressor to cryogenicaly freeze clients .
The Following User Says Thank You to Winchester For This Post:
Old 09-19-2019, 06:22:02 PM
Just completed the sunshine and set it up as a full portable, probably will take it out this weekend and give it a run at Clarendon,.... also photo session was cut short by appearance of varmint heading for the hen house!
ID:	344447   Click image for larger version
ID:	344448   Click image for larger version
ID:	344449   Click image for larger version
The Following 7 Users Say Thank You to typak For This Post:
Old 09-19-2019, 09:25:15 PM
AussieIron AussieIron is offline
All safe, the willy wagtail in bottom L/H has him covered!
Nice engine, brother has a 7 Hp, starts easy, as you say you need good spark .
Last edited by AussieIron; 09-19-2019 at 09:27:03 PM. Reason: pushed wrong button!
The Following User Says Thank You to AussieIron For This Post:
Funeral Tadsjikistan in the 30’s Brothers Clemens Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 23 07-20-2011 02:39:50 AM
