Smokstak Down Under
Big Waterloo Boy
this thread has 12 replies and has been viewed 1520 times
Old 08-07-2019, 08:56:50 PM
freshieslures freshieslures is offline
Default Big Waterloo Boy
Recently picked up this big boy
Cheers Justin
Old 08-08-2019, 11:49:05 AM
Corn Corn is offline
Default Re: Big Waterloo boy
any idea what it is ????
Old 08-08-2019, 02:53:46 PM
Jim White Jim White is offline
Great looking cart. What HP is it?
Old 08-08-2019, 10:04:35 PM
It's a 12 HP BIG CHIEF, unfortunately it's missing the water hopper so I'll probably have to fabricate one, and also missing the exhaust rocker and pivot. Not sure how many of the big ones made it to Australia. The cart was just a spare I had but it seems to suit the engine, don't no what it was originally used for.
Justin
The Following 9 Users Say Thank You to freshieslures For This Post:
Old 08-09-2019, 12:16:54 AM
Lucky the head was also off it as the skid steer only just lifted it.
The Following 7 Users Say Thank You to freshieslures For This Post:
Old 08-23-2019, 12:01:52 AM
Got the big boy into the shed and done a bit of work recently. Pulled the piston, used a chain block to help lift it out and in, made the job easy. Made new points for the ignitor, just drilled the old ones out and used nails. Made some rollers and bent up the springs, bench tested and appears to have nice blue spark. All looking good so far
Justin
Old 08-23-2019, 09:47:30 AM
Default Re: Big Waterloo Boy
If you want to make a new cast iron hopper like original for your engine, I can draw a CAD model of a mold for the hopper. There is a 3d sand printing company in Australia that can 3d print the sand mold. You would then take that mold to a foundry where it can be poured. Let me know if you are interested.
The Following 4 Users Say Thank You to Bill Hazzard For This Post:
Old 08-23-2019, 09:23:31 PM
Alastair Geddes. Alastair Geddes. is offline
Thats a good offer it will then look original as it left the factory.
The Following User Says Thank You to Alastair Geddes. For This Post:
Old 08-24-2019, 07:50:03 AM
Thanks Bill for the offer, very generous of you to help. I'll definitely let you know if I'm interested.
Justin
The Following User Says Thank You to freshieslures For This Post:
Old 08-24-2019, 09:44:21 AM
J ohn J ohn is offline
Smile Re: Big Waterloo Boy
Pic's of large hopper in USA that may be for this engine. Working with Justin on this, Opinions if this is Waterloo or Galloway hopper?? 27.5" long x 16 T x 18 wide, 10" water hole.
Anyone got actual spec's of 15 Galloway hopper or 12 / 14 Waterloo hopper?
Info on process to ship to Australia to mate to engine??? Thanks
ID:	342134   Click image for larger version
The Following 5 Users Say Thank You to J ohn For This Post:
Old 08-26-2019, 07:44:36 AM
G'day John,
I have checked measurements you have sent me, looks like it will bolt straight on. Hopefully someone will give advice on shipping it over here, otherwise I'll have to get out the row boat.
Cheers justin
Old 09-02-2019, 05:25:14 AM
Hi John,
I have been told that if I get the item packed, have it sent via Fastenal 3 PL to Cheetah exports in Indianapolis.
Thanks Justin
Old 09-02-2019, 08:42:12 AM
DavidRaines DavidRaines is offline
Not an expert but what I have seen, the hopper looks like a Waterloo Boy not a Big Chief. But better than not having a hopper!
The Following 2 Users Say Thank You to DavidRaines For This Post:
Early Waterloo Contract engine, Waterloo Gasoline Engine Co. or Waterloo Boy? Jim Martin Hit & Miss Gas Engine Discussion 2 09-03-2014 07:58:57 AM
Waterloo Boy, Waterloo Contract, Waterloo influenced Engines Ads. Denis Rouleau Hit & Miss Gas Engine Discussion 8 11-17-2013 11:40:36 AM
Waterloo Gas engine Postcard Waterloo Iowa 1910 Jim Martin Hit & Miss Gas Engine Discussion 4 10-23-2013 09:36:26 AM
Waterloo Contract Engine's (Not Waterloo Boy's) Jim Martin Hit & Miss Gas Engine Discussion 10 05-20-2013 05:31:33 PM
Waterloo Boy M.Smith Antique Engine Archives 0 12-08-2003 04:54:43 PM
