Smokstak Down Under
Watch this space, new shed to appear soon!
this thread has 30 replies and has been viewed 1796 times
Old 09-05-2019, 04:38:48 PM
Scotty 2 Scotty 2 is offline
Default Re: Watch this space, new shed to appear soon!
Hello Ian
Here's a test to see how good Builder Bob is. See if he sweeps the roof before the gutter is put up. A good tradey will.
Cheers Scott
Old 09-05-2019, 05:34:29 PM
Clapper Clapper is offline
Originally Posted by Scotty 2 View Post
Hello Ian
Cheers Scott
Already on to that one Scotty!
Cheers
Ian
The Following User Says Thank You to Clapper For This Post:
  #23
Old 09-05-2019, 08:51:20 PM
Tim B's Avatar
Tim B Tim B is offline
Nice building like that, I'll sweep the floor!
Old 09-05-2019, 10:06:16 PM
Hi Tim
Yes the floor will swept and left to dry. I will then seal it to stop grease and oil from soaking into it. Might take a while to dry after this rain event, never mind I have waited this long so a few extra days waiting for it to dry won't hurt.
Cheers
Ian
  #25
Old 09-05-2019, 10:44:08 PM
Hello Ian
These guys make some great concrete paint. We'll be using some soon (hopefully)
http://www.planetpaints.com.au/welcome/
Cheers Scott
The Following User Says Thank You to Scotty 2 For This Post:
  #26
Old 09-06-2019, 02:02:14 AM
davob davob is offline
If you want a hard wearing industrial concrete sealer at reasonable price, check out the link below. I used this in my shed and its a great product, only cost about $270 for a 20L drum from memory and only used 50l to put 2 coats on 216 square meters of shed floor. This product impregnates into the concrete unlike a lot of products that only adhere and later on peel
https://cementaid.com/wp-content/upl.../ROKITE_PR.pdf
The Following 2 Users Say Thank You to davob For This Post:
  #27
Old 09-06-2019, 02:08:50 AM
cobbadog cobbadog is offline
I agree that a protective coating should soak in first then once the pores are filled then sit on top.
By the way; How did you get all that concrete to stay up with out any signs of support?
Old 09-06-2019, 04:37:38 AM
Cobba
An extremely talented concreter and a lot of form work was used. You should have seen the struggle he had using the helicopter to finish it.
Not sure what happened there to be honest. Picture is correct orientation in my phone. Who knows what happens inside the mystery that is the internet
The Following User Says Thank You to davob For This Post:
  #29
Old 09-06-2019, 07:05:18 AM
Same happens to me but mine tend to lay down on one side. I too have no idea why it happens especially after youdownload it from the phone onto the desktop then do the retation and save and it looks great on the desktop then post it and it changes back yet it does not increase the pixels as I also have to compress the image to post.
Old 09-07-2019, 04:50:40 AM
Hi,
Roof and gutters on today, so just the ridge cap, pa door, roller door, front window and flashing. Looks like an easy day for him tomorrow.
Cheers
Ian
The Following 2 Users Say Thank You to Clapper For This Post:
  #31
Old 09-14-2019, 11:55:18 PM
Hi
Sorry for the delay had a dose of man flu. Almost done, electricians coming tomorrow to wire it up, then the plumbers to do down pipes and stormwater drainage. Once they are done I will clean and seal the floor.
Cheers
Ian
ID:	344014   Click image for larger version
ID:	344015   Click image for larger version
The Following 7 Users Say Thank You to Clapper For This Post:
X-tra Space , No Problem Paul Spence Antique Engine Archives 0 07-27-2003 11:21:18 PM
Re: Space David Greenwalt Antique Engine Archives 0 10-10-2002 09:36:40 PM
