Smokstak Down Under
Any Lister type N or R examples in Australia?
this thread has 12 replies and has been viewed 497 times
Old 08-14-2019, 05:17:10 PM
oldironoz oldironoz is offline
Default Any Lister type N or R examples in Australia?
Just wondering if anyone has seen an example of a Lister type R or type N at any rallies, museums or private collections, in Australia? I want to get a close look at one for a technical history I'm working on.
Ian Scales
Canberra
Picture from Graces Guide
Name:	Im1912IM-List - GracesGuide.jpg
The Following User Says Thank You to oldironoz For This Post:
Old 08-14-2019, 06:10:13 PM
Scotty 2 Scotty 2 is offline
Default Re: Any Lister type N or R examples in Australia?
Hello Ian
Until one is found, this may be of use. You may be able to get a guess at dimensions in the picture and compare.
By looking at the table you can see that the N and R are pretty much the same physical size.
Something else I've been wondering: When did Lister introduce the twin cylinder verticals?
Cheers Scott
PS: Sorry about the delay in the sheet picture. Been busy.
Old 08-14-2019, 08:43:09 PM
Chester Chester is offline
There is a R and N in a private collection not far from me,
there are others around, long way from you though, cheers,
Chester.
Old 08-14-2019, 09:32:38 PM
Nathan Woodruff Nathan Woodruff is offline
Here is one I think? https://www.youtube.com/watch?v=dUqtsU-o3HY it is 9hp can't remember model. Also with regards to Scotty talking about twin cylinder listers here is a fairly rare example https://youtu.be/SrluHNFweBg?t=50s
Regards,
Nathan
The Following 2 Users Say Thank You to Nathan Woodruff For This Post:
Old 08-15-2019, 02:50:16 AM
karragullengine karragullengine is offline
Regards,
Nathan
Is that a lister X?
Old 08-15-2019, 03:04:29 AM
Hello all
Ian. Can you put those pictures of the engine you want identified up in this thread? I reckon the 3rd picture (if I remember right) gives an impression of a wide engine ie twin cylinder. It would be good to see what others think.
I had a bit of a look through some of my literature and Lister had twins before 1922 and they would look different to the twin Nathan placed up in the video.
Cheers Scott
Old 08-15-2019, 03:15:36 AM
mightgo mightgo is offline
Hi oldironoz,as it happens i have a r model and am going over to canberra to-morrow,if you like i can take some pics to night brian
Old 08-15-2019, 03:20:44 AM
Here is a Lister N at the Taralga Rally in 2006
The Following 2 Users Say Thank You to Patrick M Livingstone For This Post:
Old 08-15-2019, 03:24:09 AM
This Lister R is regularly seen at the Campbelltown Steam Museum Rally.
Name:	2016-10-16 at 12-18-51.jpg
ID:	341497   Click image for larger version
Name:	2016-10-16 at 12-19-03.jpg
Old 08-15-2019, 06:11:58 PM
Hello all
For the benefit of those who missed Ian's initial thread about identifying some engines on Australian based boats I'll repost the pictures hoping someone may be able to identify the engine.
There isn't much to go on but the consensus is that the engine is a Lister. This was assumed because of the flywheel counterweight shown in one.
So here is a couple of the pictures Ian posted.....what is it?
The first pictures shows the flywheel counter weight.
There's some nice smiles on the ladies faces. One more so then the other. I had to look twice on where the point of the anchor was. Photo's can be so misleading
In the second picture I'm not sure if flywheels are sticking out each side of the tarp or not. It seems wide and that is why I'm thinking 2 cylinder. What do you think? Is it even Lister? What other engines, available to Australia, had flywheels like that?
Cheers Scott
Old 08-16-2019, 02:42:48 AM
cobbadog cobbadog is online now
I don't think that the engine is a twin, looks too narrow in the cylinder area and if it is a twin they are sitting crooked to the flywheels.
No clues as to breed of engine from me.
Hey Scotty, are you suggesting that the lady closest to the anchor is the one with the biggest smile?
Old 08-16-2019, 03:06:15 AM
Merv C Merv C is offline
Originally Posted by karragullengine View Post
Is that a lister X?
The Lister in the second video is a Lister X. I think it is 20 hp. It is a twin and very rare only a small handful in existence, there is one in the Transport Museum in Invercargill NZ.
I have an R but I am across the ditch.
Merv
The Following User Says Thank You to Merv C For This Post:
Old 08-16-2019, 03:35:02 AM
Hello Cobba
Another thing I've been researching is the thing that's tilted under the tarp in the first picture. It's at the top of the engine so I've assumed (probably wrongly) that it's the muffler. Or is it a bucket on the muffler?
The tilt may be a clue. It seems the tilt is is in a forward orientation and not a sideways orientation. Yes/no?
Unless there's another elbow in the exhaust, the muffler on a single cylinder Lister should not tilt forward or aft. They should tilt sideways shouldn't they? But the muffler on a twin can tilt forward or aft. Sound feasible?
Cheers Scott
Examples of How They USED to Haul Engines! Beth V Steam Stationary Engines, Traction Engines 126 01-28-2019 09:15:09 PM
Looking For Sidemount Drawbar Mount Examples Farmall_Doctor Steam Stationary Engines, Traction Engines 10 11-20-2018 04:05:45 PM
SUNDIESEL Type O 6hp made by H.V.McKay Sunshine VIC Australia CLARKE MAYZE Smokstak Down Under 11 02-16-2017 04:21:14 AM
Exhibit Poster Examples Odin Hit & Miss Gas Engine Discussion 11 07-21-2016 06:22:15 AM
Mogul type C Australia Joe McClelland Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 01-16-2011 11:08:11 AM
