Smokstak Down Under
Magy for 6hp International Horizontal Famous
this thread has 19 replies and has been viewed 667 times
Old 08-30-2019, 05:00:30 AM
denby denby is offline
Default Magy for 6hp International Horizontal Famous
I have the oppurtinity to purchase a barn fresh 6HP inter famous horizontal but it is missing the mag. How hard are they to find? It is reasonably complete other than that, the carby is broken off, the muffler is broken off and the rocker and mount are broken off but they are there. What is it worth in that sort of condition
Old 08-30-2019, 05:58:50 AM
Alastair Geddes. Alastair Geddes. is offline
Default Re: Magy for 6hp inter horizontal famous
well they can have a webster magneto and cast bracket with ignitor, they will be a little hard to find but i suppose if you ask there may be one lurking around.
I think the 4 to 6 hp where the same and larger engines where different but chime in to correct me if i am wrong at which size the change was.
I know of one for a larger engine but not a smaller one.
The contact i know who has smaller engines in famous line has passed away and obviously is out now for helping.
There is another option of a reproduction ignitor and run it off a coil and battery. see rob charles if he does castings and maybe even if he machines one up as well.
He may recast the webster brackets as well, but you will still need a webster mag.
on biz cards smokestak https://www.enginads.com/bizcards.shtml
contact the magneto people as well to see if they have one around if you want to go the magneto route.
There also maybe a person out there who is willing to recast the webster bracket and machine it up you can only ask, post it on the american section in antique engines. see how you go.
Old 08-30-2019, 06:17:03 AM
I should add you could have had it fitted with a ignitor and
motsinger autosparker as well but still uses battery to start it then switches over to autosparker to run.
They run off the flywheel have their own seperate cast bracket as well.
They are about and occasionally come up on eBay.
Old 08-30-2019, 06:30:47 AM
just checked eBay there is a cast bracket for a autosparker for sale now .
https://www.ebay.com/itm/BASE-for-MO...QAAOSw44BYWg2N
You still need autosparker itself, correct drive wheel for it and check mounting position for that particular size engine, some bigger engines this bracket mounts vertically so can be the wrong bracket on some applications, they vary.
Some use the one in the bay ad some don't
Old 08-30-2019, 07:17:29 AM
E27N's Avatar
E27N E27N is offline
Got any photos? Engine in that condition is probably worth $500-1000 plus a bit maybe more if the seller has a sentimental attachment to it. I paid $1000 for my 8hp at auction in 2015 and it was very rough ( photo below) but complete.
A JY 1 model Webster is the correct model for a 6 hp, be prepared to pay big $$ if you find one in the US, I’ve also found igniters are like hens teeth I’m still trying to find one for the 8hp to replace the spark plug set up im currently using.
Cant get photo to display the right way
I love the smell of 515 in the morning...
Old 08-30-2019, 10:57:35 AM
The 4&6 go engines use different brkts. The 6-8-10 use the same brkt. The trip rod and wedge are different between the Webster mag and the plain ign . The plain ign uses a straight rod which is easy to make. Repro wedges are available. Here in the US and engine in that shape would bring probably $1500 -$2000.maybe alittle more.Rob
Old 08-30-2019, 06:33:17 PM
freshieslures freshieslures is offline
Is it hopper or tank cooled, throttler or hit n miss, on a transporter? Pictures would be good, you should be able to weld up broken parts, mags are out there but do bring a few dollars.
Justin
Old 08-30-2019, 06:56:46 PM
It is tank cooled on transport. hit and miss I think. I would really like to put the correct mag on it
Old 08-30-2019, 08:18:56 PM
Scott Kocher's Avatar
Scott Kocher Scott Kocher is offline
hey denby there is a Webster mag on eBay right now for sale that should fit your engine it is a jy . item number 113580910522 I hope this helps you
Old 08-30-2019, 10:23:35 PM
I have tried that number in advanced search and it wont come up
Old 08-30-2019, 10:26:38 PM
here it is
https://www.ebay.com/sch/i.html?_fro...10522&_sacat=0
Old 08-31-2019, 12:33:05 AM
Default Re: Magy for 6hp International Horizontal Famous
found it thankyou. What do people think of the price and condition of that one?
Old 08-31-2019, 12:49:37 AM
E27N's Avatar
Grab it quick! That’s good for that price, even as a core to rebuild. New coils are pretty cheap.
https://www.ebay.com/itm/Coil-Pair-f...wAAOSwZola7GFT
Old 09-01-2019, 05:11:21 AM
does anyone know how to date them? ser # is j2205 with an E under the number
Old 09-01-2019, 05:55:00 AM
the book dates it at 1911. they built 679 of that type engine that year . you have engine number 199 off the production line
The Following User Says Thank You to Scott Kocher For This Post:
Old 09-01-2019, 06:03:35 AM
i have a list that covers most except the very early ones pm your email and i can email it to you.
Just a reminder to get onto that magneto if you want it or you will miss out on it as its a buy it now ad and can go in one click of the mouse.
organise shipping with the seller too.
I would do all that first before worrying about the date of it, its of secondary importance to making it all complete.
The date range could be 1906 to 1912 approx without looking it up.
You need the bracket with built in ignitor as well hopefully you have that bit to make it complete.
Its up to you to sort it if you want it.
Old 09-01-2019, 07:15:46 AM
pictures of the engine will help a lot. we can give you straight forward answers then
Old 09-01-2019, 07:23:09 AM
still trying to work out the sale of the engine. Don't really want to buy the magy if I cant buy the engine
Old 09-01-2019, 07:46:30 AM
Famous Fitter Famous Fitter is offline
Hi Denby
The engine number says it’s a 6hp tank cooled portable and as Scott says 1911.
The JY mag with the aluminium body would be right for this engine. They are few and far between and not often on the market. They are well made magneto so apart from worn bushes and crook coils there is little else can go wrong. The brass and die cast versions of the JY mag will fit as well.
Depending on condition and without seeing it I would say anywhere between 2-4 K for value for the engine ?( As is depending on actual condition)
The hard to get bits are the magneto, igniter, carb, fuel pump and water pump. Going by engine number this engine would have the piston water pump and screen tank.
Let us know how you get on with it - good luck
cheers Justin
The Following User Says Thank You to Famous Fitter For This Post:
Old 09-05-2019, 07:12:27 AM
no luck the seller has decided not to sell
International Horizontal Famous David Appleton Hit & Miss Gas Engine Discussion 8 08-06-2018 01:20:02 AM
1hp IHC Famous horizontal water cooled with a mag? R. Kern Hit & Miss Gas Engine Discussion 17 10-10-2014 03:57:04 PM
IHC famous 6hp horizontal headed my way CLips221 Hit & Miss Gas Engine Discussion 12 03-28-2012 12:18:49 PM
4 HP Horizontal Famous John Mathieson Hit & Miss Gas Engine Discussion 0 01-05-2012 08:05:14 PM
6hp Famous Horizontal (pull) Robbo Hit & Miss Gas Engine Discussion 0 02-04-2006 05:59:06 AM
