Smokstak Down Under
What Is It and What Is It Used For
this thread has 5 replies and has been viewed 646 times
Old 09-01-2019, 03:30:29 AM
Jim Kennedy Jim Kennedy is offline
Default What Is It and What Is It Used For
Does anybody know what this was used for. 3 cylinder radial oscilating motor. Pulley side has small soldered tubes going to ports. Looks like 3/8" barbs for inlet and outlet. I found it at a recycling centre.
I can't make out the writing on it.
Jim
ID:	342743   Click image for larger version
ID:	342744   Click image for larger version
Old 09-01-2019, 10:28:25 AM
Lester Bowman Lester Bowman is offline
Default Re: What Is It and What Is It Used For
An interesting home built or commercially built three cylinder oscillating single acting self starting engine probably meant to run on air. Interesting design The main body looks like a casting. Are the cylinders Nickel plated or are they just rusty ?
The Following User Says Thank You to Lester Bowman For This Post:
Old 09-01-2019, 05:09:22 PM
Scotty 2 Scotty 2 is offline
Hello all
Very interesting bit of kit Jim. I can red Met/chem on the long tube but cannot read the number.
Is the whole air engine made of brass or stainless?
The fittings don't really lend themselves to high pressure. For some reason the fittings say to me....vacuum, not pressure.
Cheers Scott
Old 09-01-2019, 06:19:57 PM
AussieIron AussieIron is offline
Makes me think industrial pump or milking machine pump?
Old 09-02-2019, 07:31:10 AM
cobbadog cobbadog is offline
To me it is simply a 'donkey engine' that can run on compressed air or even low pressure stem then the pully drives other accessories. Look at the model stem section in fleabay and you find all sorts of things to drive from that pulley,
Old 09-02-2019, 10:02:13 AM
PLCtech PLCtech is offline
Maybe it's a chemical feed pump for a boiler or cooling tower or a dosing pump for a liquid concentrate.
