Smokstak Down Under
Inter M fuel line question.
this thread has 7 replies and has been viewed 380 times
Old 09-03-2019, 06:34:29 PM
john gilbert john gilbert is offline
Default Inter M fuel line question.
Hi All Stakers, a question for all those that have renovated a Model "M" Inter engine. How does one fit the fuel return line "" to the brass TEE Piece on the top of the tank.?? Yes, I make the tanks but have never fitted one. A new renovator who has likewise "never fitted one" is asking me. Damn, I have no idea at all. Please help me. Cheers, John:
Old 09-03-2019, 07:54:51 PM
Ray Freeman Ray Freeman is offline
Default Re: Inter M fuel line question.
Goes the side of the mixer near the top,fuel pump side from memory.
Old 09-03-2019, 08:12:55 PM
The return line goes to the big fitting that the fill pipe screws into. The "tee" on top of the fuel tank isn't a regular tee. One side has the pickup tube that goes down into the tank; the line from here attaches to the bottom of the fuel pump. The other side of the "tee" is the tank vent and is plumbed out through the hole in the base on the governor side.
Old 09-03-2019, 08:20:32 PM
Scotty 2 Scotty 2 is offline
Hello all
The return line is the brass one you can see.
Cheers Scott
The Following User Says Thank You to Scotty 2 For This Post:
Old 09-04-2019, 06:16:24 PM
freshieslures freshieslures is offline
That's a nice finish on that little m, what have you done it with?
Old 09-04-2019, 07:34:00 PM
hit a wrong key, lt the lt, #@%$@#damn. now I will try again
Many thanks for the prompt replies. Scotty2 those pics are great mate. Thanks a million Even I can figure out what is required here now. Cheers, John
Old 09-05-2019, 03:01:18 PM
The fuel lines are 3/8 OD tubing, with compression fittings for attachment.
Old 09-05-2019, 04:43:13 PM
Bare metal and WD40 (or similar....whatever is in my hand)
The Following 2 Users Say Thank You to Scotty 2 For This Post:
RE Fuel needles for inter m Farmer 680 Hit & Miss Gas Engine Discussion 2 10-21-2012 08:54:56 AM
IHC LB fuel line question Rich Martz Hit & Miss Gas Engine Discussion 9 02-25-2010 02:44:33 PM
fuel line question Tim Venetis Generators & Electric Motors General Discussion 10 02-19-2007 07:05:44 AM
Economy fuel line question Mike Schweikert Hit & Miss Gas Engine Discussion 16 01-29-2006 03:37:06 PM
3 hp F/M fuel line question Tom/Idaho Antique Engine Archives 2 11-23-2001 11:54:27 AM
