Smokstak Down Under
Tangye Hot Tube Operation
this thread has 12 replies and has been viewed 633 times
Old 09-08-2019, 07:58:56 AM
asw20 asw20 is offline
Default Tangye Hot Tube Operation
Hi folks, I have bought / buying a 1904 4hp Tangye in bits.
I have the intake / hot tube assembly (yet to pick up the engine).
Is anyone here intimately familiar with these and could describe what the various parts of the assembly do? I have the intake tower and valve off, but there are other bits I don't understand the function of.
Old 09-08-2019, 08:09:39 AM
Default Re: Tangye hot tube operation.
There is a screw on "canister" on the left. I don't know what's in it, or what it does.
There is a bolt visible behind that. It seems to be a random snapped - off bolt with a maybe - original round nut. This looks like it could block off a small bypass passage next to the main passage.
It looks like the fuel comes in with the air via an orifice in the intake valve seat.
The hot tube sticking out the bottom of the main assembly stops flush on the inside. Is that right?
Perhaps I will see another running at Kingaroy, shortly.
Cheers, Jarrod.
Old 09-08-2019, 08:35:54 AM
E27N's Avatar
E27N E27N is offline
Hi Jarrod,
This is off the top of my head so it may not be 100% correct. The side canister contains another hot tube, under the first cover will most likely be asbestos insulation so take proper precautions there. That’s insulating a secondary chamber that houses the second hot tube, the bolt is the valve to regulate how much combustion gas can heat the outside of the tube that is used to maintain an ignition point once the engine has warmed up and the blow lamp had been shut off.
The hot tube is hollow and stops flush inside as you suspected, it will most likely be full of carbon and crud. I used a cheap masonry bit to clean it as it will destroy a normal bit.
The intake valve has a row of holes around the seat that allows the fuel to flow when it opens so ensure they are clean. There should be a spacer under the intake valve spring, it limits the valve travel to ensure fast airflow over the valve seat ( narrow gap, fast air, Venturi effect, atomises the fuel etc).
That’s what I can remember from when I restored my 10hp.
Andrew.
I love the smell of 515 in the morning...
The Following 7 Users Say Thank You to E27N For This Post:
Old 09-08-2019, 08:57:09 AM
Thanks Andrew. That explains it. It looks like I will have to heat the side canister to get it to unscrew.
I will have a closer look at the primary hot tube regarding being full off carbon.
My intake valve does have the spacer you describe, but only one fuel orifice. I did read about that bit as you describe.
Thanks again, Jarrod.
The Following User Says Thank You to asw20 For This Post:
Old 09-08-2019, 04:36:27 PM
Scotty 2 Scotty 2 is offline
Hello Jarrod.
So....where's some other pictures? You can't tease with bits and pieces pictures
Do you still need that governor bit we talked about earlier this year? It's been in my little green toolbox just waiting. I'm going to Kingaroy also so remind me if you still need it.
Cheers Scott
The Following 2 Users Say Thank You to Scotty 2 For This Post:
Old 09-08-2019, 06:14:48 PM
Kerry Morris Kerry Morris is offline
Jarrod, as per Andrew's post, contact me for a more details, Kerry Morris, Tangye Registrar
The Following 7 Users Say Thank You to Kerry Morris For This Post:
Old 09-09-2019, 03:34:27 AM
Default Re: Tangye Hot Tube Operation
Kerry; thanks for that. I will be in touch shortly. Do you have 4905 already on the register?
Scotty; yes I do still need governor bits. I don't remember exactly which bits I asked for, but mainly the pushrod. I have a cover, although it's the wrong one. (it's embossed "BALTIC SIMPLEX", but it's on an International - badged Ronnie).
Cheers all.
Old 09-09-2019, 03:36:36 AM
Not much to look at. Looks like I will be picking it up at Kingaroy.
The Following 3 Users Say Thank You to asw20 For This Post:
Old 09-09-2019, 04:41:57 AM
Originally Posted by asw20 View Post
Kerry; thanks for that. I will be in touch shortly. Do you have 4905 already on the register?.
Yes Mate, have it as a 5hp, need to check flywheel Dia and Bore to confirm if its 4 or 5hp
Kerry
The Following User Says Thank You to Kerry Morris For This Post:
Old 09-09-2019, 04:50:23 AM
I'm told it's 36", but don't know if that's approximate, or measured. Don't know what the bore is.
I'll have all the vital stats in a couple of weeks.
Jarrod.
Old 09-09-2019, 08:18:16 AM
Famous Fitter Famous Fitter is offline
Hi Jarrod/Kerry
The engine Bore is 5 5/8” , stoke around 10”
Flywheel is around 36 1/4” x 4” wide - flywheel has a small counterweight cast into the rim
I felt it was time to pass this engine on and am sure Jarrod has the skills and ability to see this project completed !!!!
Cheers Justin
The Following 4 Users Say Thank You to Famous Fitter For This Post:
Old 09-09-2019, 06:10:14 PM
Thanks Justin, records now been updated, yes a 4 hp
Old 09-10-2019, 05:52:50 AM
Based on information recieved, I have had a poke at the two hot tubes - luckily the only blockage was (mostly) wasp nests - they are practically clear. I'll still pull it apart, but it's optional now.
Cheers.
3 hp Tangye Neil Mactavish Smokstak Down Under 22 05-13-2017 05:00:09 AM
Tangye Hot Tube Russell Meadows Smokstak Down Under 1 02-09-2014 10:57:35 AM
Tangye 7HP hot tube on youtube Farmer 680 Hit & Miss Gas Engine Discussion 0 11-04-2013 08:41:24 AM
Tangye B tjcorbin Smokstak Down Under 3 08-20-2013 02:56:58 AM
Tangye hot tube? Merv C Smokstak Down Under 22 11-07-2012 04:19:24 PM
