Smokstak Down Under
Good Foundry Casting Movie
this thread has 9 replies and has been viewed 582 times
Old 09-11-2019, 05:41:34 AM
Darryl Darryl is offline
Default Good Foundry Casting Movie
I recon this is worth a look.
A little bit of Doosan Babcock history - all about the foundry casting process
https://www.youtube.com/watch?v=dqSG...ature=youtu.be
This film shows the casting process from pattern design to the finished article
moulded by hand, at the Babcock and Wilcox Renfrew works.
Old 09-11-2019, 07:32:46 AM
Nathan Woodruff Nathan Woodruff is offline
Default Re: Good casting movie
Very interesting Daryl I will have to find some time to watch it in length. Inspires me to want to learn the foundry trade shame it is dying off in Aus.
Regards,
Nathan
Old 09-11-2019, 05:58:40 PM
Scotty 2 Scotty 2 is offline
Hello all
Great period video.
It just goes to show just how labour intensive casting anything is.
To think each cast part of any machinery involved that many people and meant at least one pattern. The pattern stores must have been huge for some of the foundries.
Cheers Scott
Old 09-11-2019, 06:49:09 PM
Thanks, got home from work and started watching, got a second glass of wine and finished. Very interesing.
Old 09-11-2019, 08:39:51 PM
john gilbert john gilbert is offline
Geezzz J. B. if it took 2 glass's of wine to see this Foundry in work, I had better load the freezer with water and have a bottle of American Honey on hand before I sit to watch this one. Cheers. John
Old 09-11-2019, 11:45:03 PM
JoeCB JoeCB is offline
Default Re: Good Foundry Casting Movie
Thanks for posting, very interesting. Sure illustrates just how harsh the work environment was in the foundry in those days. Explains how both grandfathers ended up with Silicosis working at the Ford Rouge foundry in the 30's.
Joe B
Old 09-12-2019, 06:51:28 AM
Wayne Timms Wayne Timms is offline
Hi,
It looks at about 22 mins 20 sec, the casting is short poured going by the rounded edges, might be an optical illusion of the film - doesn't look right.
Regards,
Wayne
Old 09-12-2019, 07:00:03 AM
What ! I didn’t write all that, just the first line ?
Old 09-13-2019, 02:44:41 AM
cobbadog cobbadog is offline
When visiting Garden Island Dock Yards in Sydney we went into the pattern making room where they draw it up on the wooden floor to check the scale and size are correct. It is huge room and there are still drawings on the floor. Then below that room nearby is the remains of one of the lathes for machining all the long stuff including prop shafts. It took a while just to walk from one end of it to the other.
Babcock & Wilcox had a foundry and offices at Regents Park Sydney near where I grew up and a mates Aunty worked in the offices but then I discovered recently that his father who I knew was a draftsman actually did the drawings for a lot of their stuff.
Old 09-13-2019, 05:22:03 AM
Hi,
I wonder what these castings were attached to, each one is about 4 ft long.
Watching the film not much has changed, below is a markout board that I made early this century. Contraction and machining added, and the pattern making hasn't change except I prefer to put the steel extraction plate on the inside of the pattern as this avoids stripping the screws. Mind you, I'm not a pattern maker, hence the rough pattern but it still does the job.
Regards,
Wayne
P.S. Should point out that it was a good friend who machined the pattern to the correct size, and he is not a pattern maker either
ID:	343874   Click image for larger version
ID:	343875   Click image for larger version
ID:	343876   Click image for larger version
The Following 2 Users Say Thank You to Wayne Timms For This Post:
Any Home Casting/Foundry People Here? ChrisinEstes Hit & Miss Gas Engine Discussion 10 06-16-2016 06:34:03 PM
Good movie on the Amish vern0n Horse Drawn Equipment 5 03-13-2011 06:33:02 PM
Looking for a Good Foundry Elwood Hit & Miss Gas Engine Discussion 10 02-11-2011 09:08:55 PM
Small Home foundry casting tools supplier Dale Hit & Miss Gas Engine Discussion 2 06-25-2006 02:50:30 PM
Casting foundry Tanner Remillard Antique Engine Archives 3 03-31-2001 04:22:36 PM
