Smokstak Down Under
Coil and Condescer tester Kaput
this thread has 2 replies and has been viewed 288 times
Old 09-11-2019, 03:58:18 PM
Robbo Robbo is offline
Default Coil and Condescer tester Kaput
I have a Autolab A.C. Model 196 Coil and Condencer tester.
The OAK VIBRATOR UNIT Ceased to vibrate properly disableing the tester.
Would any one know where a replacement can be purchased.
Model- AC input Volts 6 6 pin VAC5124
Thanks in advance
Robbo
Old 09-11-2019, 04:54:29 PM
Scotty 2 Scotty 2 is offline
Default Re: Coil and Condescer tester Kaput
Hello Robbo.
Does that unit have an aluminium cover? If so then you can remove the cover (I put them in the lathe and spin them but a dremmel will do the same) and clean the points that are within it.
They usually get going again after a clean up. Use really fine wet and dry. 1600-2000.
Cheers then
Scott
The Following User Says Thank You to Scotty 2 For This Post:
Old 09-11-2019, 07:32:45 PM
Radiomike Radiomike is offline
Radio vibrator come in many different styles and pin configurations.
http://www.philipstorr.id.au/radio/t...al/Oak_vib.pdf
I have restored some to working condition with a light bulb like this...
http://www.skywaves.ar88.net/commrx/...g%20Up.doc.pdf
Failing this there are solid state replacement units available,
https://www.tubesandmore.com/product...tomobile-radio.
Always think about replacing any buffer capacitors at the same time.
Mike
The Following 4 Users Say Thank You to Radiomike For This Post:
Coil tester Yukon Garden Tractors and Mowers 5 05-25-2014 10:07:37 AM
IGN Coil tester debe Magnetos, Ignition Coils and Spark Plugs 1 02-12-2014 01:33:35 AM
Coil tester and mag? Scott L Magnetos, Ignition Coils and Spark Plugs 3 08-02-2013 01:01:59 PM
Coil tester ? Jason Antique Engine Archives 0 05-29-2003 07:37:06 PM
mag coil tester larry harding Antique Engine Archives 1 10-16-2000 01:00:51 AM
