IHC 3 to 5hp "LB" engines with clutch pulley.
this thread has 10 replies and has been viewed 763 times
Old 09-20-2019, 07:00:24 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default IHC 3 to 5hp "LB" engines with clutch pulley.
I have 2 of these engines, both are stuck and missing lots of parts. On a better note they both have decent clutch pulleys.
I would like to remove the clutch pulley to put on a good engine I have.
Has anyone removed a clutch pulley from a 3 to 5hp. IHC LB?
I need help on how it is done.
Thanks!
Denis Rouleau
Old 09-20-2019, 08:16:37 AM
Tom Gosciminski Tom Gosciminski is offline
Default Re: IHC 3 to 5hp "LB" engines with clutch pulley.
I have and it is not usually a simple procedure, it would be easier explained over the phone.
The Following User Says Thank You to Tom Gosciminski For This Post:
Old 09-21-2019, 02:16:45 PM
SDP's Avatar
SDP SDP is offline
The only clutch pulley I ever got for a 3-5 LB was from Ken Meeks and he used a plasma cutter....nuff said.
The Following 2 Users Say Thank You to SDP For This Post:
Old 09-25-2019, 08:24:33 AM
Still looking for help about this.
Denis Rouleau
Old 09-26-2019, 01:27:55 AM
Anyone knows if the clutch pulley is threaded onto the shaft OR if it is a pressed fit with keyway and key?
Old 09-26-2019, 06:30:05 AM
David Gregg David Gregg is offline
It is just held on by the gib key like any other pulley on a L/LB
Old 09-26-2019, 01:05:01 PM
I got the first steps from Tom in removing this type of clutch pulley but I lost communication with him:
1-remove hand wheel.
2-remove tin cover.
3-find and remove set screw.
then
4-???
5-???
Old 09-26-2019, 08:02:40 PM
4= remove the clutch spring housing by unscrewing it counterclockwise (you may need to tap it with a soft mallet CAREFULLY ! to get it moving ) 5= you will now see the gib key ! (These can also be a real pain to remove if they have been exposed to the ellements. ) 6= do not attempt to remove the back half of the clutch without removing the gib key or you will end up breaking it ! Good luck I have spent days and weeks removing these clutches, thats the reason Ken Meeks would just cut the camshaft off and sending you the project.
Old 09-26-2019, 09:00:18 PM
beechcraft1 beechcraft1 is offline
Hey Denis
Sent you a message.
John
The Following User Says Thank You to beechcraft1 For This Post:
Old 09-27-2019, 06:11:59 AM
John, I did not get your message.
Denis Rouleau
Old 09-27-2019, 09:02:31 AM
Denis
I sent it again. If you don't get it shortly give me a call later this morning or anytime tonight
204-346-2310
John
Rumely H and G "Clutch Toggle Forks" Needed. Steve Webre Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-19-2019 09:13:55 PM
Sprywheel garden tractor "hand clutch" Greg L Garden Tractors and Mowers 11 01-30-2019 04:55:09 PM
Mogul 1HP, with the unusual "BUTTER CHURN PULLEY" Paul Spence Hit & Miss Gas Engine Discussion 0 06-28-2014 09:54:01 PM
"The Reeves Pulley Co." 3hp hit miss engine CLips221 Hit & Miss Gas Engine Discussion 45 03-19-2013 07:02:02 AM
Reeves Engine Pulley "Wooden Pulley" JKWidener Hit & Miss Gas Engine Discussion 5 09-29-2007 04:42:43 PM
