Essex engine (updated)
this thread has 9 replies and has been viewed 2654 times
Old 05-30-2006, 02:50:57 PM
Mike F
Default Essex engine (updated)
have also found a essex engine, ( i think its a nelson bro,s engine ) 7hp
would like to find a few pics ..... need to know what the valve spring keeps look like ..
thanks
Old 05-31-2006, 11:51:03 PM
Bill Brock Bill Brock is offline
Default Re: Essex
Hi Mike, I've Got a 7 horse Nelson Bros. but I can't do pictures. If you want I'll take a look tomorrow and try to describe them to you.
Bill
Old 06-01-2006, 08:33:33 AM
Doug Kimball's Avatar
Default Re: Essex engine
Mike,
Here is a 7 hp Krackerjack made by Nelson Bros.
Name:	DCP_0202 (Small).JPG
ID:	9310   Click image for larger version
Name:	DCP_0203 (Small).JPG
Old 06-01-2006, 07:34:18 PM
Here are three photos of a 7 hp Nelson Bros. built Monarch engine owned by Jim McCracken.
Name:	MVC-016S (Small).JPG
ID:	9334   Click image for larger version
Name:	MVC-017S (Small).JPG
ID:	9335   Click image for larger version
Name:	MVC-018S (Small).JPG
Old 06-01-2006, 11:05:00 PM
Mike F
looks like this engine didnt have any special valve spring keeps on it ...
looks like a washer and pin will do the job.
thanks guys
Old 06-01-2006, 11:16:36 PM
Andrew Walker's Avatar
Andrew Walker Andrew Walker is offline
Photo Re: Essex engine
Mike,
If you have a 7 hp Essex, you should have a Nelson Bros Jumbo engine. Here's a pic of my old 5 hp Essex.
Andrew....
Old 06-02-2006, 10:33:20 PM
Bill Bird Bill Bird is offline
I sold a 5HP Essex engine at the Portland Swap Meet, It definitely was a Canadian engine and it somewhat resembled a Hercules in a lot of ways. It had 90% of its original dark green paint and was ignitor fired with a Webster magneto. It was a nice well built engine.
BILL BIRD
Old 06-06-2006, 07:15:19 AM
Mike F
Default essex correction
Earlier in the thread I posted that i has helping somenone work on a 7 hp Essex.
Upon better inspection, it's a 5 hp Essex and the original piston has burned up on one side. He had found one to fit it before I started helping out.
The piston that's in it now, at the top of the stroke it extends into the igniter port by 1/4 inch or so. I think it will run like this but, after time will damage this piston as well. Also I think the end wall of the piston is too thin to grind down.
any ideas ?????
thanks mike
Old 06-06-2006, 09:54:14 AM
RHudson RHudson is offline
Default Re: Essex engine (updated)
Hi Mike,
how thick are the rod bearings? could they be repoured eccentric to pull the piston/crank back alittle?
Old 06-06-2006, 10:12:18 PM
Exclamation Re: Essex engine (updated)
As long as the rings are not exposed, unless the engine is heavily loaded, there should not be a problem
Essex Hot Air Engine Mike Shaffer Hit & Miss Gas Engine Discussion 6 08-16-2012 01:54:36 AM
Stover Engine Registry Updated 1/27/12 Joe Maurer Hit & Miss Gas Engine Discussion 1 01-28-2012 05:17:47 PM
Updated videos of Holt engine running. gbritnell Scale Model Engineering 2 06-16-2009 09:20:43 AM
Myrick Engine Registry + Pix updated- new site PaulGray Oil Field Engines & Related Equipment 11 01-28-2009 12:52:17 PM
Updated IHC pump engine project. Paul Spence Hit & Miss Gas Engine Discussion 2 04-25-2005 07:29:43 PM
