Curtis compressor information needed please
this thread has 6 replies and has been viewed 1504 times
Old 02-21-2010, 12:51:50 PM
R. Kern's Avatar
R. Kern R. Kern is offline
Default Curtis compressor for display with hit and miss engine information needed please
Just aquired a really nice Curtis compressor and need to try and get some information on it and it's operation...I'd like to either e mail or message anyone that has information on these and runs them as a compressor with a hit and miss or throttler engine...I'm not interested in making it into an engine...I want to run it as a display at shows...anyone that would like, please message me or give me information as to where I can get pertinent info about this .... much appreciated. I can get specs, etc but I did see it is a 3 x 3 1/2 (assume bore and stroke) and seems to show something like 325 rpm..it has a governor in the flywheel but appears to be missing the connection to whatever it would connect with
Name:	2-21 engnine and compressor pics 001.jpg
ID:	73935   Click image for larger version
Name:	2-21 engnine and compressor pics 006.jpg
ID:	73936   Click image for larger version
Name:	2-21 engnine and compressor pics 003.jpg
Old 02-23-2010, 05:15:07 PM
R. Kern's Avatar
Default Re: Curtis compressor information needed please
Got a couple of nice replies but still looking for more information..anyone help out? Thanks
Old 02-23-2010, 06:25:47 PM
Scott's Avatar
Scott Scott is offline
I think the weights just had a spring connecting them together.
The Following User Says Thank You to Scott For This Post:
Old 02-23-2010, 07:57:59 PM
OldironPhil's Avatar
OldironPhil OldironPhil is offline
The weights do have a spring to conect them, I will get over to my other shop and dig out my curtis and take a photo for you.
Phil W Wiegman
The Following User Says Thank You to OldironPhil For This Post:
Old 02-23-2010, 08:16:31 PM
R. Kern's Avatar
My compressor has nothing to connect the flyball set up to the unloader valve...I think I understand the principle but have no idea what the mechanism should look like...if I get a look at one I think I can probably fabricate something that will work...thanks for any help
Old 02-23-2010, 08:19:45 PM
Here is a photo of my curtis may help. You should be abel to save it in your documents and enlarge it. Phil
Phil W Wiegman
Old 02-23-2010, 10:55:01 PM
R. Kern's Avatar
I think I'm on the right track thanks to your picture...My unloader valve is vertical rather than horizontal but I'm beginning to understand how things work...Thanks again for all the input and for the picture..gives me something to work on ..... when I get it fixed up I'll post a picture..but it may be a while....
curtis compressor Kevin Hit & Miss Gas Engine Discussion 16 01-22-2012 09:50:22 PM
Curtis Compressor thecj3man Hit & Miss Gas Engine Discussion 4 06-25-2011 02:28:33 PM
Curtis compressor Denis Rouleau Antique Engine Archives 4 05-16-2004 11:21:39 PM
Curtis Air Compressor Wesley Phillips Antique Engine Archives 6 11-29-2002 04:06:39 PM
Curtis Air Compressor Tim Wilson Antique Engine Archives 0 12-31-2001 07:49:35 PM
