Stewart Warner Hand Tach
this thread has 12 replies and has been viewed 3351 times
Old 06-13-2013, 07:09:32 PM
Mike Schweikert's Avatar
Mike Schweikert Mike Schweikert is offline
Images: 26
Default Stewart Warner Hand Tach
I picked this up, and wanted to know its age and if anyone had instructions for it.
Its a Stewart-Warner hand tach S-96336 and other 96335, high and low RPM as well as clockwise and counterclockwise rotation.
Anyone else have one?
Thanks!
Mike
ID:	167350   Click image for larger version
ID:	167351   Click image for larger version
Mike Schweikert
Jamison PA
See my videos at: http://www.youtube.com/user/standardtwin1
The Following User Says Thank You to Mike Schweikert For This Post:
Old 06-13-2013, 10:44:36 PM
mschreiber mschreiber is offline
Default Re: Stewart Warner Hand Tach
yes i have same one in a blue painted wood box not a naugahyde box like yours. i posted over on hamb board years ago without any good exact use results. my box and gauges have the winged sw logo, might be older.
The Following User Says Thank You to mschreiber For This Post:
Old 06-14-2013, 07:21:18 AM
oops, only my box has the logo.
Old 06-14-2013, 09:44:05 AM
John Dunn John Dunn is offline
The disc would be for measuring surface speed, maybe feet per minute, if set up with the right gauge.
Old 06-28-2013, 11:12:53 PM
Junk Iron Junk Iron is offline
Have the same tach. Got it for 10$ years ago, hace used it alot & it is very accurate. I have checked it against an eletronic on I picked up later on & for most work I prefer the mechanical. The base is marked for high & low, put the gage in & spin by hand to check for correct rotation. With some light grease on the gears it will last forever, no batterys & pretty bulit proof. You have to do some math to use the wheel on a shaft you can not get to the end to read, its the ratio of the wheel to the shaft times the shown RPM. Enjoy. Mine is in a blue painted box, but no logo. I'm jelous but i still love mine. Junk Iron
Old 07-03-2013, 06:05:45 PM
Dwayne Oxford Dwayne Oxford is offline
Got 2. Mine go either way. They're precious.
Old 09-27-2013, 03:49:12 PM
WesPete66 WesPete66 is offline
Question Re: Stewart Warner Hand Tach
I've purchased a tach of similar design, except it is Swiss made. It also came with a set of various shaped tips, and the wheel for checking surface speed. The problem is the "rubbery" tip material has gotten quite hard & brittle over time. Is there anything to be done to soften this material, or make it more pliable? Or can they be coated/dipped with something to give them more grip?
Thanks!
Old 11-03-2013, 08:48:34 PM
Xylene will help some for awhile.
Old 11-04-2013, 11:44:46 AM
RSCurtis RSCurtis is offline
I have a Jacquets Indicator that is an actual rev counter. It will measure to increments of 2 RPM. I'll post a picture of it later today.
Old 09-07-2018, 08:15:06 AM
Can someone please explain how to use the wheel in this set. Better yet are there any instructions you can share?
I put this set away 5 years ago (Mikes' original posting) and would like to finally use it.
ID:	318134   Click image for larger version
ID:	318135   Click image for larger version
Lauson - Stewart Warner Aircraft Heater Craig DeShong Small Air Cooled Gasoline Engines 6 05-27-2013 09:00:19 AM
Stewart Warner Tach Zero? Kyle K Antique Gas Engine Discussion 16 03-03-2013 10:40:49 PM
Stewart Warner Wind Charger Jeff P Smith Solar and Wind Power for Home, Farm & Industry 4 07-29-2010 01:09:18 PM
Wisconsin Tach Question? Jim M. Wisconsin Engines 6 01-16-2010 02:43:26 AM
Experience with Tiny-Tach diesel tach? Bob Greene Generators & Electric Motors General Discussion 22 04-10-2005 10:48:11 PM
