Old School Band Filers
this thread has 3 replies and has been viewed 677 times
Old 04-14-2018, 05:27:59 PM
Sunnyside Sunnyside is offline
Default Old School Band Filers
I'm looking for some stories on how band filers were used, likely in die making?? Grob made one they called the FAB-18, and some DoAll bandsaws could accept band files. I assume band filers and die filers went extinct pretty much at the same time? I've seen them referred to as "lappers". None of the band files that I have are that fine--was there a different meaning?
I have used my Grob band filer on a wide variety of materials-phenolic, steel,aluminum, etc.- without issues. Slow stock removal, but friendly to work on. More of a "get it to fit" type machine- at least the way I use it.
Any recollections would be appreciated-------
The Following User Says Thank You to Sunnyside For This Post:
Old 04-14-2018, 05:58:17 PM
Card Sponsor
Default Re: Old School Band Filers
I have the filer attachment for 1 of my Doalls and a couple of band files. I never tried it out. I also have a die filing machine which I used a few times but not lately. Rob
The Following User Says Thank You to Rob Charles For This Post:
Old 04-14-2018, 10:24:52 PM
Well, lately I have been using this Harbor Freight
"Bandfile Belt Sander":
https://www.harborfreight.com/53-amp...der-62863.html
I know it's not exactly what you are asking about, but it works great for me.
I am using it to square up and finish hardy holes in anvils that I make from pieces of railroad rail.
This tool uses a 1/2" wide by 18" long sanding belt. A few friends use them for many finishing applications where it's hard to get into corners, etc..
Several years ago I bought a Harbor Freight hand held air powered die filer, too. I used up all the extra files that came with it. Not a great tool and now they don't even list it or have parts. I have found a couple of places that sell the files, but getting the Bandfile Belt Sander, I don't need it.
Pete Stanaitis
Old 04-15-2018, 08:22:04 AM
Your hand held probe belt grinder is way more useful in general shop work- I have one too and they are great. And certainly in your application, boosting a anvil onto the table and threading the band file thru the hardy hole shows how specialized/limited these machines were.
Bera Band Saw Brian.P Machine Shop and Tool Talk 1 11-01-2017 11:33:44 PM
Old School Twist On New School Pulling Tractors' 30-90 Russell Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 08-18-2013 08:52:40 PM
Band Saw 0002tense Machine Shop and Tool Talk 14 04-01-2011 06:11:41 PM
Which way does the mag band go? Tim Claremont Antique Gas Engine Discussion 2 01-15-2009 11:10:51 PM
