Generator Oil Change Intervals 3600 RPM Gas
this thread has 49 replies and has been viewed 7142 times
Old 11-15-2018, 03:32:07 PM
Tim0477 Tim0477 is offline
Default Re: Generator Oil Change Intervals 3600 RPM Gas
What was the reason for the tear down at 4k? Some other part than the engine give up the ghost? Cam finally wiped out?
Tim
Old 11-15-2018, 06:23:41 PM
Thaumaturge Thaumaturge is online now
Tim
Sorta. Cam was actually cast, but rivet on decompression pall worked loose alowing pall sideways movement... where it beat the crap out of cam drive gear on crank. Damage to gear enough to bind between crank and cam. Only damage to engine, but sufficient to DOA it. Wasn't a problem for other use as I had several brand new straight cranks. But trashed gen taper crank. So have good non-gen motor.
Doc
This mind left intentionally blank
Old 11-17-2018, 07:15:53 PM
Newoldstock Newoldstock is offline
Hmm....
I find it hard to believe.
Everything just looks too clean.
Old 11-18-2018, 12:46:52 AM
Originally Posted by Newoldstock View Post
Hmm....
Believe what you will. Internal condition is reason why I took pictures.
Doc
Old 11-18-2018, 12:50:31 PM
Doc
Worth further investigation.
I will look for that stuff and try it.
What is the exact name of the product?
Old 11-18-2018, 01:17:17 PM
Pure molybdenum disulfide powder. (The "moly" in "moly grease") One time treatment is one rounded teaspoon mixed with third oil change. Combined with drainplug magnets cleaned every oil change. Oil change at least every 100 hours runtime.
https://www.amazon.com/Molybdenum-Di...enum+disulfide
Doc
  #47
Old 11-18-2018, 08:27:25 PM
Worth trying!
reminds me....
I remember you used to be able to see the graphite powder in some oils.
Grand Pri brand snow machine oil had to be shaken well to keep it in suspension and over time you could see the black layer in the bottom of a gas can.
Old 11-28-2018, 05:39:46 PM
Have now also uploaded pics of crank gear and loose cam decompression pall which explains what killed engine. You can clearly see damage to cam drive gear.
Doc
https://drive.google.com/folderview?...EJjaUItWlpqQkk
  #49
Old 11-28-2018, 11:37:24 PM
turtmaster turtmaster is offline
Hmm, I don't see any of the new pictures.
The Following User Says Thank You to turtmaster For This Post:
  #50
Old 11-29-2018, 12:23:12 AM
Just checked, link sharing is enabled. Should see total of ten pics. One shows crank end, one shows me holding cam with loose decompression pall that did damage to engine. (Reason for teardown.) I probably ought to just upload all pics I took during teardown.
Doc
Update: Okay I uploaded ALL pics I took during teardown. The good, the bad, the redundant and the ugly. (I tossed a couple in the bit vapor bin, due to being too blurry.)
1800 rpm Onan with 3600 rpm generator Graycenphil Generators & Electric Motors General Discussion 37 07-15-2013 08:40:13 AM
Onan MDJE 7.5 Change to home generator fiberform Onan Generators 8 09-30-2012 08:53:33 AM
Question re. Homelite Textron Generator G-3600-2 walkingbc Generac Generators (SEARS, etc.) 3 09-21-2010 05:58:58 PM
Autolite generator voltage change question Kenny Short Antique Farm Tractors 1 05-19-2009 10:22:03 AM
Flywheel Sears Craftsman 3600 generator ron_a Generac Generators (SEARS, etc.) 2 04-08-2007 12:19:06 PM
