Induction motor with flat belt pulley?
this thread has 7 replies and has been viewed 4462 times
Old 05-21-2005, 04:42:41 PM
dragon dragon is offline
Question Induction motor with flat belt pulley?
Hi, Were these motors used on line shafts or did they have other applications?
It is GE 3 hp, 110v, single phase and very heavy. Thanks.
Old 05-22-2005, 12:54:25 AM
BobRR BobRR is offline
Default Re: Induction motor with flat belt pulley??
I remember seeing a very old factory built air compressor that had a electric motor using a flat belt to drive it. I believe it was original. BobRR
Old 05-22-2005, 07:59:39 AM
Harvey Teal Harvey Teal is offline
Those motors were used on everthing...they replaced the overhead line shafts. Typically you would see one bolted in place next to a saw, planer, lathe, drill press etc and the original lineshaft woud still be in the ceiling, with belts disconnected, gathering dust because too much labor would be involved to take it down. I thought those motors would be around forever, but they have now pretty much disappeared. Every now and then you can still find one hooked up tho its wall-mounted starter or compensator.
Old 05-22-2005, 08:57:02 AM
Harry's Avatar
Images: 312
In the system that I acquired, the engine and generator was located outside in a power house and back inside the machine shop, this motor powered the line shaft for lathes, mills, drill press and grinders.
See this link for the full system: http://old-engine.com/fm15ge.htm
Old 05-23-2005, 03:08:48 PM
Smile Re: Induction motor with flat belt pulley??
Thank you for the great information. I don't know what I'm going to do with this motor, but it nice to know some history about its use. Thanks.
Old 03-03-2017, 10:21:10 PM
Old motor Kid Old motor Kid is offline
Hi, Dragon
I was wondering if you still have the motor that's in this post^.
If you do, and don't have a use for it, I am getting in to collecting antique electric motors and have a few. One of them is just like this one (General electric Induction motor type KT), but mine is only a 1 horse and 3 phase 220v. Would you consider selling it, I would be interested in buying it to expand my collection, and this one would be the big brother of my other GE motor.
Sincerely,
Ron
The Following User Says Thank You to Old motor Kid For This Post:
Old 12-01-2018, 01:22:33 PM
davehall44 davehall44 is offline
Hello Ron,
I also have a GE KT 3 phase 1 HP motor, I'm cleaning it up for use. I see that the 2 plain bearings for the rotor are each lubricated with brass oil rings dipping in oil baths. On the non shaft side, the outer end of the bearing looks like it seized a little, will ream it another .001" I checked on the motor and on the net for an oil grade - you don't happen to know it thanks? I'm thinking it needs to be a lighter viscosity after doing a calc. from the net. regards, Dave
Old 12-01-2018, 03:31:12 PM
In non-scientific experimenting with one of my Century motors, I found that the lighter the oil, the less the friction. The limiting factor became the oil ring spinning too fast, slinging the oil out. That was with the sumps filled with WD-40 while I was cleaning it. It had extremely low friction, far less than ball bearings.
Flat belt pulley HalfKeck Steam Stationary Engines, Traction Engines, Steam Boats 4 09-14-2016 10:10:02 PM
flat belt pulley ronny p 148 Farm + Industrial Antiques and Collectibles 15 08-17-2012 06:42:59 AM
Need help with a flat belt pulley? JDcrawler Antique Farm Tractors 6 04-20-2011 11:37:35 AM
Flat belt pulley lonnie Antique Engine Archives 2 05-10-2004 09:09:07 PM
FLAT BELT PULLEY ROBERT OTTO Antique Engine Archives 0 11-22-2003 11:54:46 AM
