Wisconsin/Winpower Need Help Pricing a Generator
this thread has 20 replies and has been viewed 989 times
Old 09-24-2018, 02:01:04 PM
Newoldstock Newoldstock is offline
Default Re: Wisconsin/Winpower Need Help Pricing a Generator
Originally Posted by Vanman View Post
Lol! A little rabble rousing, eh? Those sellers really are out of touch.
I appreciate what you're saying. But I just don't like modern stuff. It's difficult for me to put a finger on it, but I guess it comes down to design philosophy. With old stuff, it is evident that they were proud of what they were building. Modern stuff appears as if they absolutely couldn't care less.
It *might* be 120/240 three phase, four wire. "Delta high leg". My favorite.
Only in America.... ( and little colder America like, Canada by default )
Not trying to crank people up here but Delta high leg and Edison 3 wire are about the stupidest things ever.
We should be on 50hz and 240/380 systems
I am even quite excepting of ring circuits if it means cheaper less wire and and safer.
Old 09-24-2018, 02:34:05 PM
Vanman Vanman is offline
If we go back to the beginnings, incandescent lamps were and are more efficient and more rugged when designed for lower voltage, and of course the systems themselves are more efficient at higher voltage.
US bulbs enjoyed considerable superiority over their European counterparts, and the Edison three wire system makes up the shortfall of the lower system voltage (in part, at least). So, in that context, the system is brilliant. Of course everything is a compromise of some sort.
Agreed, ring circuits are a definite advantage.
I like the delta high leg system since it supplies 120 volts for those items that require it, and a full 240 volts, single and three phase, for everything else. I have never liked 208 volts.
Old 09-24-2018, 02:38:30 PM
scotty scotty is offline
I was able to get a few more pics of the generator tag. And I don't know what a 4 leg delta high is, but the schematics I found for the unit idicates 4 legs off the armature? I think it was three powers and one neutral? Forgive my lack of knowledge with electricity. I think it is a misprint on the tag though, because the spec sheet indicates it as a 120/208 (for model # GR15W4-D).
I'll put a link in here to the schematics and specs I found.
SCHEMATICS http://www.wincogen.com/wp-content/u...parts_list.pdf
SPEC SHEET http://www.wincogen.com/wp-content/u...spec_sheet.pdf
ID:	319470   Click image for larger version
ID:	319471   Click image for larger version
Old 09-24-2018, 02:44:07 PM
[QUOTE=scotty;1515901]I think it is a misprint on the tag though, because the spec sheet indicates it as a 120/208 (for model # GR15W4-D).
Although, I should add that the actual model # on the tag (GRW15W4DN) is not the same as the spec sheet. That was the closest I could find for a model #.
Old 09-24-2018, 03:10:46 PM
I don't know where you got information like that.
The higher the operating voltage the whiter, brighter and more efficient.
Yup Edison, but he was no Tesla HA HA...
I don't think 208 likes you very much.
Hash tag #Me208!!!
Please laugh at my jokes.
But I am serious about the light bulb part.
We all know what we like and have reasons for it.
Old 09-24-2018, 03:33:21 PM
Off topic...277 volts doesn't like me. It bites hard!
Old 09-24-2018, 03:34:49 PM
Interesting. I hate typos on nameplates, but the kw, kva, amps, and pf are all in agreement for a 120/208 voltage.
Once you get it running and generating, a voltmeter will reveal the truth.
Newoldstock, yes, laughing at the jokes.
It is indeed a fundamental characteristic of incandescent lamps, that two otherwise identical bulbs- watts, rated life, basic design, etc, when designed for different voltages, the lower voltage lamp will have higher output, higher color temperature, and higher lumens per watt.
This is due to the fact that concentrated filaments are more efficient. This is why filaments evolved from the single strand of around ~24" long (for 120 volts), to the single helix of two or three inches long, then to the double helix that's only an inch or so long. So, a filament that is half as long and twice as thick (ie designed for 120 volts vs 240 volts) will be more efficient, all else being equal. Obviously there is some lower limit of practicality, and that would vary with lamp size.
If you look up the specs for 240 volt lamps, they are notably less efficient when compared to otherwise identical 120 volt lamps.
And, of course, the thicker filament is always going to be more rugged.
Old 09-24-2018, 04:44:06 PM
Higher you go the more likely you are really not going to like it.
You had me starting to doubt myself.
But I went to wiki and they say a 100 watt bulb at 120 volts is 17 lm per watt and at 230 13 lm per watt.
SO your right!
Not sure how I go to where I was, maybe thinking the efficiency goes up with the wattage?
Not sure, but I owe you a beer.
We should make bets like this that are really hard to collect on.....
Then we never run out of beer.
Old 09-24-2018, 06:57:14 PM
Kevin K Kevin K is offline
You might try selling it as a running engine, the way this Craigslist seller is doing:
"4 cylinder Wisconsin engine connected to a generator set up to run on propane was swapped out for a new generator. Great engine for many uses. Very clean $500 "
Old 09-24-2018, 07:49:02 PM
That is a different animal.
OHV V4 still in production.
Cheap too!
Selling my PE-95K generator,pricing help. wa5moe Military MEP and Aircraft Gen-Sets 2 04-21-2017 05:55:16 PM
WinPower Generator with a 5hp B&S. Dreadpunk Generators & Electric Motors General Discussion 0 05-26-2014 10:05:40 AM
Wisconsin-Winpower Genset northumberland Wisconsin Engines 5 03-16-2013 08:19:17 PM
Winpower Wisconsin Tom Kilgore Generators & Electric Motors General Discussion 2 05-09-2009 04:39:30 PM
winpower ac generator HELP! please. jay Generators & Electric Motors General Discussion 1 05-04-2004 10:35:12 PM
