Petter Diesel Winpower generator
this thread has 2 replies and has been viewed 650 times
Old 09-23-2018, 07:43:32 PM
landreo landreo is offline
Default Petter Diesel Winpower generator
Nothing special, just some photos of my hurricane generator. I have not needed it yet but you never know!
1963? Petter PAZ1 diesel engine spinning a WinPower 1500 watt generator. I added the tank on top for longer running time. It will start from the generator with a 12 volt battery but I usually just use a homemade ratcheting crank on the shaft. It typically will start on the first crank.
It weighs a bit over 300 pounds for only 1500 watts so I added a removable hitch to help move it up to my driveway. It will roll easily once on a driveway but getting it there is a bit of a struggle. The small generator in the front is a Master Mechanics 1200 watt generator, similar age, for size comparison.
ID:	319387   Click image for larger version
ID:	319388   Click image for larger version
ID:	319389   Click image for larger version
The Following 6 Users Say Thank You to landreo For This Post:
Old 09-23-2018, 09:54:20 PM
Default Re: Petter Diesel Winpower generator
The best kind of generator one can have.
Does it run almost all day on a tank of fuel? Diesels being far more efficient to operate.
Robert
Old 10-08-2018, 08:14:01 PM
It uses around 0.2 gallons per hour so a tank should last around a day.
Not an Onan, but it's green! 1950s? Winpower 7.5 125 250v 1800 Diesel Gen YellowLister Onan Generators 57 11-19-2018 09:06:43 AM
WinPower Generator with a 5hp B&S. Dreadpunk Generators & Electric Motors General Discussion 0 05-26-2014 10:05:40 AM
Petter AA1 1kW Diesel Generator LiverpoolDave Vintage Diesel and Oil Engines 0 05-08-2012 10:52:35 AM
Older Winpower diesel Genset Jim K. Generators & Electric Motors General Discussion 0 11-30-2004 09:50:57 PM
Petter diesel generator inquiry David Graves Antique Engine Archives 3 05-16-2002 04:23:27 AM
