Homelite Generator Carb Parts?
this thread has 11 replies and has been viewed 657 times
Old 10-01-2018, 04:02:02 PM
Railroads Railroads is online now
Default Homelite Generator Carb Parts?
Hi everyone, My neighbor just got a Homelite 2500 watt generator for free because the engine won't run. Turns out the engine was left setting for a year with gas in it and the carb is a mess.
What is the part numbers for a rebuild kit for this engine?
Briggs & Stratton Model 1334112 Type 007002 Code 960618YA
Homelite Model LR2500
I can't seem to find the engine doing a search for Briggs 1334112 Carb Rebuild Kit?
I need a carb kit and crank case breather rubber parts for both ends of the steel tube.
Robert
Old 10-01-2018, 04:19:42 PM
Default Re: Homelite Generator Carb Parts?
That's one of the new throw away carbs. All you can do is find some of the good berrymans carb soak and let it set in it for a day. Other than that, replace the diaphragm I've got some of those, I can mail you, if needed.
Old 10-01-2018, 04:24:49 PM
Joe Romas Joe Romas is offline
Try this for B&S parts listing.
https://www.briggsandstratton.com/eu...rt-number.html
I've found NAPA is a decent source for small engine parts as most of the small shops close up.
Old 10-01-2018, 07:09:38 PM
diaphragm? This is a float bowl type carb that is on this engine. Neighbor wont leave the dang gen with me for servicing. I have to go to the gen which is a pita for looking for part numbers and stuff. Argh! Closest I can find is Briggs 133412 which seems to show the same parts that I had in my hand today. The carb bowl gasket is falling apart and the inside was just full of rust.
What is a part number for a replacement carburetor for this engine? I am thinking this would be the better option at this point. Just slap it on and get err going.
Robert
Old 10-01-2018, 07:21:33 PM
I was assuming it was the engine with the carb bolted to the tank.
Old 10-01-2018, 07:24:05 PM
For some reason there is an extra scratch mark on the engine ID tag. The correct number is Briggs 133412 Type 007002 Code 960618YA.
This kit seems to match up to what I need. https://www.repairclinic.com/PartDet...rHelpVideoTabs
Robert
Old 10-01-2018, 07:36:58 PM
Great, didn't mean to mis-lead you on which carb was on your uniit.
Old 10-01-2018, 08:40:26 PM
No problem. This gen has been pretty hard to find anything at all on the web. Briggs site does not seem to be able to find any engine with those numbers or I'm doing it wrong? Was hoping for a parts diagram for the Carb atleast.
Robert
Old 10-02-2018, 05:49:54 AM
RETCPO RETCPO is offline
Try searching for
Briggs & Stratton Small Engine Model 133412/0059-01
Your original posting had to many ones in it.
The Following User Says Thank You to RETCPO For This Post:
Old 10-03-2018, 07:06:45 PM
Found the part number of the original carb and it's a discontinued product and don't seem to have any substitute part? Seems several folk are looking for the same carb online. I hate this throw away crap. Carb should be one of the rebuild-able components. Screw the freakin EPA. These nut jobs make more pollution than these small engines do in a year and then some.
Robert
HOMELITE 24a115-2 Generator parts Tectonator Garden Tractors / Mowers / Scooters 3 03-30-2015 11:24:52 PM
Homelite Generator Carb Danny77 Generators & Electric Motors General Discussion 1 05-08-2012 03:15:46 PM
Carb parts for WWII Vintage Homelite Pump MFaragher Farm + Industrial Antiques and Collectibles 0 04-12-2009 05:50:37 PM
What spare parts should I keep for my Homelite generator leo v Generators & Electric Motors General Discussion 1 10-30-2006 09:13:54 AM
28 Volt Homelite Generator Parts Pete B Generators & Electric Motors General Discussion 2 01-04-2005 12:43:18 AM
