Wiring External Capacitor Motor
this thread has 7 replies and has been viewed 626 times
Old 10-05-2018, 02:41:58 PM
opus opus is offline
Default Wiring External Capacitor Motor
So I am trying to rewire this motor and am kinda uneducated. This is the motor:
I am trying to make it a simple on/off switch instead of a momentary switch. In the picture I put arrows. Blue is the start capacitor? Orange are relays, green is momentary switch to start the motor and red is a microswitch that when opened, shuts off the motor. Is this possible?
Old 10-05-2018, 06:40:59 PM
PLCtech PLCtech is offline
Default Re: Wiring external capacitor motor
To replace the momentary switch with an on/off switch, remove the jumper on the bottom relay which jumpers the coil wire and the contact wire. These are the two terminals on the left side in your picture, one above the other. If you also want to eliminate the microswitch, just hook the white wire to the terminal the black wire from the microswitch is attached to. That is the bottom right terminal of the top relay.
The Following User Says Thank You to PLCtech For This Post:
Old 10-05-2018, 10:04:02 PM
OK, got it. Can I eliminate the relays totally? I have 20a toggle switches.
Old 10-06-2018, 05:41:15 AM
A switch to run a motor should have a kw or hp rating. Your 20 amp switch should be ok. The white wire goes directly to the motor. The switch interrupts the black wire. The green gets connected to every exposed metal part including the switch green terminal, if it has one. If you could mount your switch in a grounded box with a matching switch cover, that would be safer.
Old 10-06-2018, 11:39:33 AM
OK. i just looked 20v/20a so obviously I will find a different switch.
Thank you for your help!
Old 10-06-2018, 03:39:39 PM
Can you post a picture of your 20 volt switch?
Old 10-06-2018, 04:36:03 PM
Default Re: Wiring External Capacitor Motor
Its actually just a lighted auto toggle switch it seems, 9-20v. I'm after a proper switch. I was thinking they were something different, just cheap things.
Old 10-08-2018, 01:30:17 PM
One more question; If I was to put a resettable circuit breaker on the motor, I assume it would be between the capacitor and the switch, going to the motor, which is the red wire. Or would it be in the white wire?
On the breaker there are 2 post, line and load.
How will the uF of an AC induction motor capacitor affect the torque of the motor? realflow100 Generators & Electric Motors General Discussion 6 05-27-2015 01:21:35 PM
Need a capacitor for my 1944 GE Type 5KC motor K-Tron Generators & Electric Motors General Discussion 7 10-18-2013 10:15:47 AM
How does a run capacitor value affect the motor? paulmars Generators & Electric Motors General Discussion 20 04-29-2011 07:17:07 PM
R.I. motor conversion to Capacitor start Adam Kelker Generators & Electric Motors General Discussion 4 05-09-2010 08:23:03 PM
Motor start capacitor? krawlr Machine Shop and Tool Talk 6 10-18-2008 01:42:48 AM
