US Motors AA21A Generator
this thread has 12 replies and has been viewed 733 times
Old 10-10-2018, 01:57:30 PM
JohnFM JohnFM is offline
Default US Motors AA21A Generator
Any of you folks here know the color codes or have a wiring diagram for that old AC Generator?
TIA for any help.
Old 10-10-2018, 09:38:00 PM
circuitman circuitman is offline
Default Re: US Motors AA21A generator
is this a gas powered unit? i have a US motors unit, runs good but smokes a lot. really old!
Old 10-11-2018, 07:10:13 AM
It's driven by a Briggs ZZ built 7/44.
Yeah, it getting old, almost as old as I am.
Old 10-11-2018, 11:24:16 AM
This generator has 4 leads. Green, Black, Red, and bare ground.
This morning I checked voltage at the Red and Black leads again. They're the same. All I can figure is that 2 separate circuits could be run for a total of 13 Amps.
Nowadays that doesn't sound like much, but when this thing was built, that was a LOT of electricity.
My house was built in 1947 and it had ONE outlet in the Kitchen.
Old 10-11-2018, 01:02:23 PM
Joe Romas Joe Romas is offline
Or the 2 seperate circuits output 220 volts maybe??
Old 10-11-2018, 01:46:02 PM
Possible. If it was newer that's what I would think, especially with the wire colors.
The plate on the generator reads 115 volts at 13 amps.
Maybe there was another version for 230 volts or 115/230.
I dunno.
Old 10-11-2018, 02:09:13 PM
Vanman Vanman is offline
It's also possible they brought out the DC from the exciter...
Open up the brush cover and have a look. Should do that anyway to make sure everything is clean and all of the brushes move freely in their holders.
There should be two collector rings and a commutator. The two solid collector rings are the AC output, and the segmented commutator supplies DC for the field (excitation).
Follow all of the wires to see where they go, maybe post some photos.
Old 10-11-2018, 02:20:11 PM
Yeah, I've had it all opened up to see how things looked inside.
I have it open now trying to figure out where the ground wire was connected.
The end that went inside the generator looks like it was never connected to anything. Don't really know why it wasn't hooked up if they had it installed.
I'll try and get some photos of the internal guts.
Old 10-11-2018, 04:54:21 PM
As can be seen there are brushes on all 3 places. It's all still pretty clean in there except for a little corrosion showing on the brush holder springs.
All 6 brushes look like they have a lot of life left in them.
Just taking the covers off is about as far as I want to go. Don't really want to disassemble the thing.
One thing I can't find is where that ground wire that was with the leads coming out might have been attached. I figure there must be a place on the main framework somewhere, but I sure can't find it.
I think I'll run a ground wire from the receptacles to the breaker box ground buss, then to the #9 wire attached to the generator mounting plate, and from there out to a ground rod and see if that shows a correct ground on my tester.
Old 10-11-2018, 10:08:07 PM
K-Tron K-Tron is offline
John,
My AA21 says that it is rated 115volt, 13 amp @ 1800rpm. I have not seen these set up for 230volt before. That sure is a nice picture you uploaded. Your generator is nice and clean inside. I was not aware that it had a DC output of any kind. It is not mentioned on the nameplate, and the engine sure does not need any DC current to run. I wonder if the generator can excite and start the engine if a 12v battery is connected. I did nothing to my generator other than spray the valves with oil, lube the cylinder and add some light oil to the generator grease cups.
Chris
General Motors 2-71 Generator reid070 Vintage Diesel and Oil Engines 7 11-19-2017 02:38:58 PM
US Motors Generator 2.5kw RobertStengl Military MEP and Aircraft Gen-Sets 2 01-26-2013 04:16:36 PM
US Motors generator Paddyboy51 Generators & Electric Motors General Discussion 1 11-19-2009 11:15:42 AM
U.S. Motors Generator, Need Info Mike Blauer Generators & Electric Motors General Discussion 2 09-29-2006 11:14:29 AM
Us Motors Generator Mark Generators & Electric Motors General Discussion 2 12-20-2001 03:02:35 PM
