Mystery Machine! AC Generator? Double Current Generator?
this thread has 2 replies and has been viewed 546 times
Old 10-14-2018, 01:36:39 PM
Vanman Vanman is offline
Default Mystery Machine! AC Generator? Double Current Generator?
This unmarked two pole machine is rather odd. It seems that it ouputs 120 volts, AC at around 1800 rpm, making 30 cycles... More testing is going to be required. Please see the video for more details.
https://youtu.be/jLn4F93-d6o
Keith
Old 10-14-2018, 05:17:03 PM
Default Re: Mystery Machine! AC Generator? Double Current Generator?
The only 30 Hz application I am familiar with is the ring voltage for telephones. I think the actual voltage was in the 90-105 volt range. This may have been the ring generator for a large PBX system, and driven by a fractional HP electric motor.
The Following User Says Thank You to Steve Dawkins For This Post:
Old 10-14-2018, 06:21:11 PM
radiodoc radiodoc is offline
I kinda lean toward a DC motor operated rotary converter possibly to 110 volts 25 cycle...Perhaps to power some 25 cycle device from only 110 Vdc mains. Or maybe I just stepped over into the twilight zone?? Allie
The Following 2 Users Say Thank You to radiodoc For This Post:
MEP-004a Generator burnt current transformer shackwrrr Military MEP and Aircraft Gen-Sets 25 07-07-2013 10:36:16 PM
Onan BGE spec C no current output from generator RDF Onan Generators 33 08-14-2012 09:32:01 PM
Elliott Alternating Current Generator Jeremy Williams Generators & Electric Motors General Discussion 4 03-01-2012 07:58:40 PM
Current Mil-Design Generator Production EricWood Military MEP and Aircraft Gen-Sets 1 03-18-2011 06:03:36 PM
OLD OLD Double Current Generator Gus Simms Generators & Electric Motors General Discussion 4 03-31-2004 11:12:36 PM
