GE Dynamo Generator
this thread has 3 replies and has been viewed 576 times
Old 10-16-2018, 08:52:54 AM
Matthew Guy Clarke Matthew Guy Clarke is offline
Default GE Dynamo Generator
Can anyone difinately advise me how to hook this up or test it. Jon says one can hook a 12 volt battery to it turning it slowly ?
ID:	320909   Click image for larger version
ID:	320910   Click image for larger version
The Following User Says Thank You to Matthew Guy Clarke For This Post:
Old 10-16-2018, 09:47:28 AM
Radiomike Radiomike is offline
Default Re: GE Dynamo Generator
The first step would be to clean it all up and see if there is a data plate hidden some where. The next step is to check the wires for any markings, such as A (Armature) or F (field). There seems to be four wires in the terminal box. Trace these wires, check their continuity and make a sketch of the wiring. The two heavier wires probably go to the brushes, and maybe a connection to the four field coils. The two lighter wires are probably the shunt field windings. Make sure the brushes are clean and free to move in their holders.
Check that you have to ground faults in the armature or the field coils.
https://en.wikipedia.org/wiki/Shunt_generator
Mike
The Following 3 Users Say Thank You to Radiomike For This Post:
Old 10-16-2018, 12:47:49 PM
Have a look at the brushes. Do they fit against the armature at an angle, or are they at right angles to the segments (straight away)? if angled, the armature should turn against the angle - that is toward the brush. if you motor the unit, and it turns against the brush, you need to reverse the polarity of the battery, so as not to damage the brushes.
You could try and motor the unit with a 12 volt battery to see if the armature is good, by attaching the armature wires to the battery. You would be advised to use a small battery first so if there is a problem, you don't fry the windings.
You could try belting it up temporarily to an electric motor, just to spin it up. Depending on how fast you can spin it, it may show you how much voltage it can make, depending on RPM. If no tag is on the unit, this probably is your best bet. Personally, unless other wise indicated, I would not turn faster than about 1200 RPM. Depending on how it's wound, your output could be anywhere from 24 to 130 VDC, again, depending on windings and RPM. Looks like a neat project, sure would make an interesting display! from the first look, I would suggest a 3 HP engine to turn it, if you want to make good power. if just turning for show, or very light load, maybe a 11/2 or 2 HP throttled engine would work well.
If this unit is a motor, you may find that it can turn at about 1750 - 1800 RPM. Have you tried to contact GE about this unit?
Old 10-16-2018, 08:29:41 PM
Greg Mosley Greg Mosley is offline
Greetings MGC, Couldn't make out what the tag said in your pix. Could you supply the data? Thanx.
1904 Era Hercules Accessory Generator/Dynamo John Walters Antique Gas Engine Discussion 1 12-08-2018 03:45:35 AM
Edison DC Generator (Dynamo) CW OP Generators & Electric Motors General Discussion 3 08-03-2012 09:46:53 AM
What is this dynamo/ generator for? JKWidener Magnetos, Ignition Coils and Spark Plugs 0 12-27-2010 10:16:23 AM
Need Generator or Dynamo BobSaunders Generators & Electric Motors General Discussion 11 01-19-2009 10:14:37 AM
Looking for a large Dynamo-Generator Ron Generators & Electric Motors General Discussion 0 10-17-2004 08:44:41 PM
