Adding AVR to Capacitor Alternator?
this thread has 19 replies and has been viewed 892 times
Old 10-20-2018, 02:15:05 PM
cjjmw cjjmw is offline
Default Adding AVR to Capacitor Alternator?
Hi all,
I'm new to the forum and I'm hoping someone can help me with a project I'm working on.
Is it possible to add an AVR to a cheaper 10kw 240V (120X2) capacitor excited brushless alternator?
All I see on the schematic is two film caps on the main assembly and two diodes and two varistors on the rotor.
Am I right in thinking those varistors are what's doing the actual regulating?
Old 10-20-2018, 02:52:02 PM
Default Re: Adding AVR to capacitor alternator?
Won't work. Non brush type generators use harmonic excitement of field. Made to work within a small range of output Hz, either 50 or 60 depending on where marketed. (Meaning designed specifically to run at frequency where sold.)
Might check wikipedia for further information, but bottom line is won't work!
Doc
"There is always some yayhoo turning left!" - my father.
The Following 2 Users Say Thank You to Thaumaturge For This Post:
Old 10-20-2018, 02:59:42 PM
Doc
That was simple.
Old 10-20-2018, 03:50:44 PM
Originally Posted by cjjmw View Post
That was simple.
Sadly yes. I have a number of small generator heads I would love retasking to run at lower RPM to feed an inverter design. It was investigating such that I learned myself just how difficult it would be.
Doc
Old 10-20-2018, 04:36:34 PM
Doc
Just how bad are these at regulating assuming no huge load changes?
I noticed Briggs and Stratton claims it'll run a 3 ton air conditioner. Sounds like a bad idea to me for anything else running at the time.
Old 10-20-2018, 08:00:05 PM
Newoldstock Newoldstock is offline
Default Re: Adding AVR to Capacitor Alternator?
Not that bad.
The idea is as the load increases the harmonics generated in machine increase and this is what induces the current in the rotor.
The caps resonate at the right frequency, diodes convert AC to DC and supply the field.
No complicated and not the best regulation but they hold well enough to do what most people need.
Not so good for electronics
The varistors are important.
They trim off and spikes and peaks induced from switching and sudden changes.
Without them the diodes may fail and your output AC might get some noise and spikes too
The Following User Says Thank You to Newoldstock For This Post:
Old 10-21-2018, 10:24:54 AM
Jim McIntyre's Avatar
...Non brush type generators use harmonic excitement of field...
Huh.
I'm sort of familiar with the 'capacitor-regulated' generator the OP describes (more here: http://www.freepatentsonline.com/4786853.pdf and here: https://patentimages.storage.googlea.../US4296368.pdf)
And I'm sort of familiar with some of the Chinese generators that have a 'harmonic winding', but they have brushes.
So, can you provide any link to a reference that says more about 'harmonic excitement' in a brushless generator?
Old 10-21-2018, 11:07:35 AM
armandh armandh is offline
there are brush-less systems traditionally regulated.
these have a primary alternator with a stationary field, and rotating rectification of the field current for the main alternator.
this is very much different than the cap regulation.
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
Old 10-21-2018, 11:15:10 AM
^ Yes, well aware of that.
I'm curious about thaumatuge's brushless, harmonic-excited machine...
Old 10-21-2018, 04:21:21 PM
Originally Posted by Jim McIntyre View Post
...I'm curious about thaumatuge's brushless, harmonic-excited machine...
As am I...
Brushless Alternator with Capacitor Jim McIntyre Generators & Electric Motors General Discussion 30 07-24-2016 10:22:03 PM
porter-cable brushless alternator with capacitor Ronarm Generators & Electric Motors General Discussion 6 05-30-2016 06:39:33 PM
Capacitor Excited Brushless Alternator zzdodge Generators & Electric Motors General Discussion 24 03-28-2015 07:26:50 PM
Dayton 1W832 Alternator B&S 9hp no power from Alternator Rickfa Generac Generators (SEARS, etc.) 6 01-25-2015 01:35:42 AM
Onan MCCK 6500 FWC adding an separate alternator? sdowney717 Onan Generators 3 06-11-2012 08:09:09 AM
