Would you trust this?
this thread has 15 replies and has been viewed 1136 times
Old 10-25-2018, 03:17:40 AM
cjjmw cjjmw is offline
Default Would you trust this?
Hi all,
So I finally pulled apart a generator I've been working on that currently has no output. The windings test good, and it's been assumed the caps just need to be flashed but I pulled it all apart because I wanted to see the physical condition of the genhead.
This apparently was at a beach house for most of it's life and it also looks like a mouse was living in it.
Would you trust this? The color of a few windings concerns me as does a green spot on one. Does this mean the insulation is compromised?
ID:	321441   Click image for larger version
ID:	321442   Click image for larger version
ID:	321443   Click image for larger version
Old 10-25-2018, 05:22:49 AM
armandh armandh is offline
Default Re: Would you trust this?
exactly what tests?
you need to first test the windings for resistance to ground
https://www.google.com/search?q=mege...nt=firefox-b-1
if you can't borrow a "megger"
a high voltage source and a FET front end volt meter will do
Probably could not find it among all the junk but I had a low current KV supply
3v bat, osc, xf, doubler rectifier out of one of these
https://www.google.com/search?q=elec...nt=firefox-b-1
if leaky to gnd probably not worth the effort unless you can get one similar with a bad engine
if it is a typical pacific rim junkerator it probably was not trust worthy when new, less so now.
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
Old 10-25-2018, 07:20:14 AM
Originally Posted by armandh View Post
exactly what tests?
The only tests I could do using a typical ohm meter. Best I can tell nothing is shorted to ground, at least not at a few volts.
Don't own a megger and have no where to borrow one from.
Old 10-25-2018, 01:04:40 PM
Vanman Vanman is offline
I think the green spot is disconcerting. It may not give trouble, for a while, so long as it is always dry (no condensation) when run. Might try to carefully clean it and apply some varnish.
Not knowing the design, I am guessing that the few darker colored turns may be a different winding. If they are shorted turns, it wouldn't run long at all like that.
Being two pole (high speed) I would agree that it's likely not worth doing a whole lot to it, if it turns out to need something major.
Old 10-25-2018, 01:16:19 PM
akirkland akirkland is offline
3600 rpm gensets that have been living at the beach are always 1 start away from being toast. No, I would not trust it.
The Following User Says Thank You to akirkland For This Post:
Old 10-25-2018, 01:24:34 PM
I wish I could find a decent 2 pole 8-10K genhead somewhere close by.
I've got the perfect engine to go with it.
Old 10-25-2018, 01:26:52 PM
georgineer georgineer is offline
I can't see anything there which would come to any harm if it got wet, so if it were mine, I would give it a thorough wash in fresh water to remove all the muck, sea salt and murine urine. Possibly rinse it with distilled water if I was feeling fussy.
Then I would put it in a warm - not hot - place for days or weeks to dry out thoroughly. I would use an ordinary £5 multimeter to measure the resistance between the windings and the metal frame (which I presume has a ground/earth terminal on it somewhere. If not, scrape a little patch until bare metal shows.)
I would be looking for a resistance of at least 1 megohm, which is the minimum acceptable insulation resistance under UK portable appliance testing rules. US rules may be different. If it is less than 1 meg, stick it back in the warm place for a few days and see if it improves. Repeat until the reading levels out, at which point you can assume it is thoroughly dry.
Obviously the multimeter test is at a very low voltage, but if the resistance won't come up to at least 1 meg then you know the thing is done for and you can throw it away. If it does show over 1 meg, you can choose whether to get a test done at working voltage or above, or reassemble it and give it a try. (Following safe practices, whatever happens isn't my fault, and other necessary disclaimers.)
George
P.S. Incidentally, with motors it is often successful to leave them running on no-load for a few hours to dry the windings out. I recently improved a 1920s motor which had been in storage for years from 300 kilohms to 5 megohms - something like a 15 times improvement.
The Following 2 Users Say Thank You to georgineer For This Post:
Old 10-25-2018, 01:34:46 PM
George
I was actually wondering if I could use brake cleaner on it. I believe it leaves very little residue behind. But I was concerned about it attacking the varnish.
Using a Fluke DMM I was unable to measure anything between windings or to ground. I'm fairly confident they're good, right now, with the tools I have at hand.
Old 10-25-2018, 02:08:42 PM
I would not use brake cleaner on it. Use electrical contact cleaner. Works just as good, won't attack insulation and dries with no residue.
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 10-25-2018, 08:13:54 PM
So, what about rusty laminations. The stator and rotor cores?
Does surface rust cause issues?
Warne Trust Auction Bubbles Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 04-07-2017 06:43:34 PM
