Would you trust this?
this thread has 15 replies and has been viewed 1098 times
Old 10-25-2018, 08:46:44 PM
Thaumaturge Thaumaturge is online now
Default Re: Would you trust this?
Give it first a good vacuuming, then high pressure air cleaning. Then a good soap and water bath followed by lots of fresh water rinse. Let dry a full week in a low humidity environment. Paint over any visible copper where varnish may have been nicked. DO NOT bend or disturb any windings, that may only make it worse. IF ohm tests show no shorts between windings and frame then maybe subject windings to hipot test. You should be more concerned with leakage between windings and frame than winding to winding. If all shows good lightly clean surface rust of laminations, wipe down with alcohol then spray clear laquer over laminations. Rusty laminations aren't really a concern as they will only decrease efficiency, not prevent operation.
Short of vacuum dip varnish treating of coils that's about the best you could do.
Doc
This mind left intentionally blank
Old 10-26-2018, 05:46:25 AM
georgineer georgineer is online now
Originally Posted by Thaumaturge View Post
... Then a good soap and water bath followed by lots of fresh water rinse. ...
Doc
Doc,
I'm not sure about using soap as it can be very difficult to wash out of crevices, but otherwise I agree with all your thaumaturgic advice. The main purpose of the wash, as I see it, is to remove any salts and other things which attract moisture, and to leave no deposits.
George
The Following User Says Thank You to georgineer For This Post:
Old 10-27-2018, 02:00:11 PM
After giving the machine a good cleaning and let dry out for a week then get a spray can of glyptal https://www.electro-wind.com/glyptal...quart-can.html
Robert
The Following User Says Thank You to Railroads For This Post:
Old 10-27-2018, 02:48:37 PM
cjjmw cjjmw is offline
Robert
I washed it out the best I could without disassembling it.
I've had a few tell me the rusty stator core won't matter. I hope they're right.
ID:	321595   Click image for larger version
ID:	321596   Click image for larger version
Old 10-27-2018, 02:51:50 PM
Once it's dry I'll try running it again and flashing it.
If it goes as planned, it'll get new caps and I'll take care of the connections.
Robert
Hi Robert,
How clean do I have to get things to use the varnish?
Old 10-28-2018, 08:28:25 PM
Your at the point of being able to use the varnish if everything has thoroughly dried out. Trapped moisture will lead to failure of the windings.
Rusty lamination stacks don't hurt anything. If anything the rust will insulate the stacks which will stop eddy currents from flowing in the iron laminations. At least that is what some old time transformer books say about the subject.
Make sure to replace any badly corroded connections with good quality crimp connectors. I like to use a ratchet style crimper tool like the pros use to make sure I get a firm high quality connection when replacing crimps.
Good luck.
Robert
Warne Trust Auction Bubbles Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 04-07-2017 06:43:34 PM
