the holliday season is comming
this thread has 0 replies and has been viewed 380 times
Old 10-29-2018, 11:15:18 AM
armandh armandh is online now
Default the holliday season is comming
I am re-posting a simple cure for those balky HO [etc] trains.
smoothest operating [try it]
the attached power supply can be made from a handful of junk box parts.
NO IR LAG OR OVER-SPEED
you raise the speed control and the voltage goes up proportionately.
[up to the current capacity of the components, fuse should be weakest]
there is minimal current effect on the applied voltage.
the stout active device should have a heat-sink
you can substitute an old printer wall-wart for the xf/rectifier end
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
ES6500 smoke comming out of the generator flkeysff Honda, Yamaha, Kawasaki, Isuszu Generators 19 12-14-2013 12:30:41 PM
Holliday Gas Engine (Chicago) Info wanted Craig Solomonson Antique Gas Engine Discussion 14 06-04-2013 08:13:07 PM
Renfro Valley KY show this comming weekend Earnie Hampton Oil Field Engines & Related Equipment 1 10-04-2006 02:45:14 PM
Snow show comming up Kevin Beitz Antique Engine Archives 3 12-04-2002 08:24:58 PM
Holliday Engine Alan James Antique Engine Archives 0 12-26-2000 03:39:18 AM
