Purposely running a 3600rpm generator at lower speed
this thread has 15 replies and has been viewed 901 times
Old 11-03-2018, 09:57:57 AM
DustyBar DustyBar is offline
Default Re: Purposely running a 3600rpm generator at lower speed
Originally Posted by Thaumaturge View Post
Watts = Volts x Amps. If 120 = 1000W then 112 = ~877W)
Doc
Actually it will be something less than 877 I think. From the rated wattage you can calculate the heater's resistance. Then apply that resistance to the lower voltage and I'm pretty sure it will be less than 877. Sorry I'm not sure of the formula but from experience I've seen that. Not that it matters...just a note that is the way it works.
Old 11-03-2018, 12:08:24 PM
Fred M. Fred M. is offline
I think the problem with running the generator slow, is that the power available may be proportional to the square of the speed. If this is correct, running a 1000 Watt generator at half speed, you would only have 250 Watts available.
For a specific load, you could probably find an ideal speed, so power available is equal to the demand.
Fred
Old 11-03-2018, 02:35:43 PM
Dropping to 3200RPM shouldn't be a problem for the engine.. what voltage comes out of it depends on the type of voltage regulation.
This is the perfect use for a smaller generator, say 3HP Briggs or Tecumseh, or dinky 80cc Champion, just stick to a 4-stroke.. cheap, lightweight, quiet, expendable.. For teeny-weeny engines, 3600RPM really isn't that big of a problem
Old 11-03-2018, 03:04:17 PM
Unhappy Re: Purposely running a 3600rpm generator at lower speed
Engine cooling should not be a problem at lower speeds,, nor should be oiling. Starting an air cooled splash engine in cold weather is. You will need to use a 5W-30 or even a 0W-20 if extremely cold, to prevent bearing starvation. SAE 30 will not work in a splash system under 40F. Certainly, running the gen end at lower speeds will cause cooling issues, especially if loaded. As noted, running at lower speeds will lower voltage and available amps. The heater will not put out the rated heat either, with the reduced power. In that case, reducing speed of the engine is self defeating - the block will not be heated as needed, and the gen set will not do as designed - make enough power to make the heater work as designed.
Old 11-07-2018, 10:46:44 PM
turtmaster turtmaster is offline
If the voltage is a bit too low at 3200rpm, why not use a ~24v ac step down transformer wired in "boost" configuration.
Old 11-07-2018, 11:02:05 PM
Newoldstock Newoldstock is offline
Just make sure there are no motors involved.
Years back I remember the parking lot at Pamour mine had big warning signs not to use a car heater only plug in your block heater.
But up in the near north there was always someone trying to run a 60hz interior car heater on 25 cycle and things would go wrong and burn up
detroit 3-53 nock in lower end untill oil pressure comes up and idel running high jehepe Vintage Diesel and Oil Engines 5 03-22-2015 09:32:12 PM
Question about Generator Speed and Motor Speed iceman Generators & Electric Motors General Discussion 7 06-12-2010 02:08:08 PM
Running a Novo at slow speed? Jim Koehler Antique Gas Engine Discussion 12 08-24-2009 10:32:01 PM
Internation LB only running at low speed jmayo Antique Gas Engine Discussion 3 09-08-2008 09:30:13 PM
How do I adjust running speed? bjaspud Maytag Engine Collectibles 4 10-26-2007 12:21:55 AM
