20 vac motor
this thread has 15 replies and has been viewed 565 times
Old 11-09-2018, 06:47:38 PM
opus opus is offline
Default 20 vac motor
[Might not be the right place for this so let me know]
I have a 20vac 2a motor that I want to run off of 120vac. How can I do this reasonably? Its only a test so I dont want to have to throw a chunk of money at it.
Old 11-09-2018, 06:59:01 PM
Default Re: 20 vac motor
You need a 120v to 20vac transformer rated at 5 amps to run a 2 amp motor.
Robert
Old 11-09-2018, 07:00:39 PM
And this would work?
https://www.sustainablesupply.com/Pl...1Y714-C1159187
Old 11-09-2018, 07:04:07 PM
Ed Radtke Ed Radtke is online now
you can use a variac transformer,then when your done with your experiment you will have another useful tool in the shop.
The Following User Says Thank You to Ed Radtke For This Post:
Old 11-09-2018, 07:08:09 PM
Christmas is coming, need my address?
If it gets to be something i am going to continually do, then yes, I will get one of those.
Old 11-09-2018, 07:18:42 PM
Radiomike Radiomike is offline
Many automotive battery chargers use two diode full wave rectification with a centre tapped transformer. This will give you around 20 volts AC RMS before the rectifier. The most basic battery charger without electronics would be best. If you modify a battery charger check the volts before you make expensive connections.
The link https://www.sustainablesupply.com/Pl...1Y714-C1159187 is only for a 16VA power supply you need 40 VA to just give you 2Amps.
What is the motor for and what type is it?
Mike
Old 11-09-2018, 07:23:34 PM
It's a popcorn hot air popper fan motor. I do have a power supply that's 24 volt output with 1.875 amp. From what I have read that 20 volt motor will take 24 volts, make sense?
Old 11-09-2018, 07:26:41 PM
If the motor is a brushed type it might run on DC which would open up possibilities.
Robert
Old 11-09-2018, 07:45:51 PM
Jack Hottel Jack Hottel is offline
Look for a 120/24V, 40VA or larger control transformer. Used on all HVAC equipment, probably can find a used one from a junked unit.
Jack Hottel
Old 11-09-2018, 08:14:48 PM
Power Power is online now
That is 20% over rated voltage. I would not run it on that for long. Being a tinkerer, I would look over my stuff. I would probably try an auto headlamp with low & hi beam filaments wired together in series with motor.
Dayton motor bicycle motor AltWord Small Air Cooled Gasoline Engines 0 12-20-2016 02:23:53 PM
GE washer motor and other motor wiring help webbys rigginations Generators & Electric Motors General Discussion 37 07-05-2016 01:05:25 PM
How will the uF of an AC induction motor capacitor affect the torque of the motor? realflow100 Generators & Electric Motors General Discussion 6 05-27-2015 01:21:35 PM
Westinghouse 1.5 induction motor help (compressor motor) eeprete Generators & Electric Motors General Discussion 20 10-30-2014 04:41:22 PM
Motor Brushes for a Vintage Motor Twincreek Generators & Electric Motors General Discussion 4 11-08-2011 01:07:07 AM
