20 vac motor
this thread has 15 replies and has been viewed 576 times
Old 11-09-2018, 08:21:06 PM
opus opus is offline
Default Re: 20 vac motor
How about a dimmer switch?
Old 11-09-2018, 10:25:49 PM
DMeed DMeed is offline
If it has brushes it likely can run on DC.
Just for a test you can likely run it on 12V (car battery) IF it will run on DC. It will run about 1/2 speed
Old 11-09-2018, 10:27:07 PM
Good to know, but it needs to run full speed.
Old 11-10-2018, 12:21:21 PM
armandh armandh is offline
Originally Posted by opus View Post
16 VA / 20 V = 0.8 A
do the math
I would try a 24 V xf and see what V you get under load for a short test
you can drop AC volts with 2 sets of series diodes or zinners [one set each direction parallel]
or a resistor if the load is constant. blower load is air volume dependent.
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
Old 11-10-2018, 12:46:52 PM
I quit doing math when the alphabet got involved.
Old 11-10-2018, 10:17:03 PM
then be thankful there are those who did not.
the less complicated way....
2 amps times 20 volts is 40 watts [way more than 16]
CAVEAT EMPTOR
YMMV
Dayton motor bicycle motor AltWord Small Air Cooled Gasoline Engines 0 12-20-2016 02:23:53 PM
GE washer motor and other motor wiring help webbys rigginations Generators & Electric Motors General Discussion 37 07-05-2016 01:05:25 PM
How will the uF of an AC induction motor capacitor affect the torque of the motor? realflow100 Generators & Electric Motors General Discussion 6 05-27-2015 01:21:35 PM
Westinghouse 1.5 induction motor help (compressor motor) eeprete Generators & Electric Motors General Discussion 20 10-30-2014 04:41:22 PM
Motor Brushes for a Vintage Motor Twincreek Generators & Electric Motors General Discussion 4 11-08-2011 01:07:07 AM
