Fordson Distributor
this thread has 1 replies and has been viewed 485 times
Old 04-29-2017, 06:34:00 AM
Nate Bolduc Nate Bolduc is offline
Default Fordson Distributor
Last night, I pulled my Fordson out of storage and went to fire it up. When I went to retard the spark, the "distributor" wouldn't move. I was able to tap it to retard it, but it is still hard to move. I didn't take it apart and was wondering what was going on there?
At least it fired right up!
Old 04-29-2017, 05:23:23 PM
Ed Bezanson Ed Bezanson is offline
Default Re: Fordson Distributor
Nate I assume you are talking about the timer that controls the coils on the side of the block. It is connected to the dash so it can be advanced or retarded when needed. It should rotate freely where it is mounted off the end of the camshaft. Disconnect the connecting rod and try to rotate it with your hand. I don't know much about this system since I put cam drives on most of my tractors. Good luck Ed B
Distributor Cub Cadet Olf20 Magnetos, Ignition Coils and Spark Plugs 3 07-15-2015 07:50:15 AM
Distributor, What Have I Got Here? Nevr-Enuf-Stuf Antique Farm Tractors 2 07-31-2013 09:04:51 AM
Aenld distributor Kelley Hulsey Wisconsin Engines 2 01-26-2013 08:16:51 PM
Distributor JD Canuck Magnetos, Ignition Coils and Spark Plugs 2 01-21-2012 10:58:19 PM
Distributor Marty Antique Engine Archives 0 09-09-2003 08:53:44 PM
