Help Identify Wheels
this thread has 9 replies and has been viewed 944 times
Old 10-02-2017, 07:32:14 AM
chas2545 chas2545 is offline
Default Help Identify Wheels
looking to find out what these wheels are for I purchased them thinking McCormick deering 22-36 the splines are the same but the width is about two inches shorter, they do not have the oblong hole in face like other mccormicks and the width of center hub is only 7 1/2 inches and normal in like 8 to 81/2 I can not find and casting numbers any help is appriciated.
The Following User Says Thank You to chas2545 For This Post:
Old 10-02-2017, 07:39:34 AM
Default Re: help identify wheels
here is some more pics
ID:	292721   Click image for larger version
Old 10-02-2017, 09:33:54 AM
Russ Hamm's Avatar
Images: 1
Diameter of the rim should tell a lot.
---------- Post added at 08:33:54 AM ---------- Previous post was at 08:32:45 AM ----------
Also, what does the seal side look like?
Old 10-02-2017, 11:13:12 AM
the diameter of the wheel is 48'' I am also attaching a pic of the inside side of wheel. this all started because I was going to put steel on a WA-40 that I have and I have read that 22-36 will fit other than the holes where the washer fits. cleaned splines all up pushed on and was puzzled by the extra approx. two inches of spline I had and nothing said anyplace about using a bushing. proceeded to measure my 22-36 that has steel and there is a 2'' width difference in hub. and also they measure I think 50'' in diameter. I am leaning that these are not even mccormick because if you look even the face is different.
Old 10-02-2017, 03:04:41 PM
halcon halcon is offline
Could be 90 Oliver. WD9 McCormick uses that spline but I think they are also 50"
Old 10-02-2017, 03:13:08 PM
K Cooke K Cooke is offline
The W9 spline length is shorter than W40 or 22 36. But the diameter? Have to check the W9 parts book. I put W9 wheels on W40 and had to make a spacer about 3 inches long
Old 10-02-2017, 03:15:39 PM
Russ Hamm's Avatar
Images: 1
Thats what i was thinking also, and sorry about the seal side comment, i see the seal side now. W-9 or W-6 depending on the diameter, looks like 9 just guessing. I have been looking for some W-9 rears, by the way.
Old 10-02-2017, 07:06:38 PM
Inter Bloke Inter Bloke is offline
Yes, I recon the others are correct with W9, I have a pair up on the farm that look the same and from memory the size is about right, unfortunately I don't live there now so I can't check it out for a couple of weeks. W6 is considerably smaller, you couldn't mistake them for W9 even in a photo.
Old 10-04-2017, 07:37:10 AM
Default Re: Help Identify Wheels
thanks for the all the help to identify these. this is a funny thing. I had two wd-9s in the past on rubber. sold them not sure now to keep these or sell now not having a tractor and how hard fronts are to find. again thanks for all the info.
Old 10-04-2017, 08:33:22 AM
Russ Hamm's Avatar
Images: 1
Yep, reason i'm looking for rears is i have fronts.
Can anyone identify these wheels? N84434 Garden Tractors / Mowers / Scooters 4 10-09-2016 08:29:02 PM
Help me identify some steel wheels spartan10311 Horse Drawn Equipment 0 03-02-2011 03:03:56 AM
IHC Cart? Wheels, can you Identify? JimS Antique Gas Engine Discussion 3 11-06-2010 08:03:31 AM
Help identify wheels! Ken Jochem Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 11-20-2009 07:15:13 PM
Trying to identify some wheels? fast72lemans Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 03-29-2008 09:06:12 PM
