Wallis Troubleshooting?
this thread has 31 replies and has been viewed 2891 times
Old 01-02-2017, 04:44:06 PM
G Willikers G Willikers is online now
Default Wallis Troubleshooting?
Pulled the head off the 20-30 Wallis today in order to change the valve springs. Definite seating issues evident on 3 and 4 exhaust valves so they will all get a grind. I have a couple of questions for the experts:
- would it help to place rings (washers) under the valve springs to give them even more tension? Anything like that available?
- I had gotten a new Olsen head gasket and they also supplied one piece manifold gaskets. Does anyone supply the original style ring type manifold seals?
- does anyone make new push rods?
- regarding the little patented brass schnorkenwobblebimpler device (pictured below) that I assume is for water feed, does it effect running of motor if not set properly? If memory serves, there is a little rotary valve system that opens ports and runs off butterfly.
The tractor has never ran just right, at least at idle. When working, it seemed to settle in fairly nice. Also, it got hard to start in later times. Would it help to put proper priming cups on the intake somewhere. I am never sure whether fuel gets into the cylinders through those little straight primers that are on it. All my other tractors start so easily and I can't figure out why the Wallis is sometimes so hard to fire up.
At any rate, maybe I have asked this all before but thanks for any help anyway.
Aloha,
RM.
Old 01-02-2017, 07:18:05 PM
RustyRelics UK's Avatar
RustyRelics UK RustyRelics UK is offline
Default Re: Wallis Troubleshooting?
Hello G Wilikers
Could you post a picture of the small brass linkage on the back of your vaporizer which controls the throttle butterfly, I am this small piece missing to get my 20-30 up and running. Could I trouble you to measure the hole centers from the butterfly shaft to the linkage point.
I need to make something up to make this work and it would be a great help to start in the ball park.
Thanks in advance
Carl Hargreaves
Old 01-02-2017, 08:13:44 PM
Phil Johnson's Avatar
G, most engine machine shops in my experience have a selection of shim washers that can be installed under valve springs to correct for differences in height. The Wallis springs are fairly light if I remember correctly (as I've worked on a few of them) and might benefit from shims. I have a complete 20-30 here as a "yard ornament", but have never looked under the valve cover.
I had a very nice Wallis 12-20 which went to the Reynold's Museum a couple of years ago and it always started very easily with only one pull over with choke on and then one more with it off and away it went! Never used priming cups.
Old 01-02-2017, 09:52:54 PM
Rusty,
I'll look into that tomorrow.
Phil,
Thanks for the help.
Old 01-02-2017, 10:36:06 PM
Oldtech Oldtech is offline
Yes, washers can be placed under the springs. Any machine shop should have various sizes. Only restriction is if the spring coils bind when valve is open. I don't think that'll be a problem on a Wallis. The springs seem soft as these engines only run 1000-1200 rpm. Don't need big springs,.
The Following User Says Thank You to Oldtech For This Post:
Old 01-02-2017, 10:55:51 PM
TSeaberg TSeaberg is offline
Hi Rick, Good to see you are working on the Wallis again. I sent you new valve springs right? For some of your questions the brass water valve does not have an adjustment on it. The holes just line up at or near wide open and then water flow is regulated on the starting tank valve according to the operators book. I usually plug this line to prevent a vacuum leak as well as the priming valves. When starting mine I just use the choke a couple times and that is enough.
For the exhaust gaskets I have been just cutting my own rings out of felpro gasket material. Its a pain to work with but in the end it looks better.
Some items I go through when trouble shooting mine. Check the camshaft timing. Easy to do and surprisingly many of them are off. I have had two of my own tractors with camshaft timing off and they idle horribly but run better at higher speeds and pulling. Easy way to check is to use a dial indicator on the exhaust valve or rocker arm and see that it closes about 10 degrees after TDC, or 8-1/8" to 8-5/8" from inside of the frame on carb side to timing marks on front pulley.
Then make sure the vaporizer is air tight but I think you have already went through that. fix anything that can be an air leak. The Kingston carbs are not the greatest for idle adjustments but the valve or flapper inside of them should be pretty tight side to side and at least seal all the way around the hole. Float level can be adjusted to change idle a little bit. Most of the time I spend a few weeks or even months working on running characteristics for each new tractor learning all the time.
The Following 2 Users Say Thank You to TSeaberg For This Post:
Old 01-03-2017, 07:27:59 AM
Tom,
Thanks for the advice. Yes, you sent me the valve springs a couple of years back. I like old Wally but feel sorry for him as he is the neglected work horse in the stable. I'll try to fix that. I don't know how people have dozens of tractors and manage to look after them all. Four keeps me going!
Old 01-03-2017, 01:17:51 PM
Rusty,
Here are some pix of the pfnortzbrakensplotz which is opposite of the schnorkenwobblebimpler device. I hope this is what you wanted?
For hole centres, I am looking at 5/8 inch (1.5 cm).
Should you need better pictures or measures, please let me know.
Hope this helps.
ID:	271661   Click image for larger version
ID:	271662   Click image for larger version
ID:	271663   Click image for larger version
The Following 3 Users Say Thank You to G Willikers For This Post:
Old 01-03-2017, 02:57:41 PM
Brothers Clemens's Avatar
Thumbs up Re: Wallis Troubleshooting?
Rick hope your problems are soon fixed again.
You have an nice yelly sandwich and it Looks to me peach jam or something.
Hope you left something for me.........
We have already the new AP this afternoon about the chase tractor.
In an coople of weeks it wil also arriving in the North American mail boxes.....
Keep continude your wonderful story’s,
Chris,
Old 01-03-2017, 02:57:54 PM
Russ Hamm's Avatar
Images: 1
Dunno, but i'm hankerin for a sandwich and some coffee right now.
Troubleshooting a 5k and a 3k RJs Vegas Onan Generators 5 08-02-2010 09:21:26 PM
G-193 Continental Troubleshooting gnarles Farm + Industrial Antiques and Collectibles 3 04-29-2009 09:07:08 PM
Troubleshooting 3HP IHC M jmsolomonson Antique Gas Engine Discussion 6 04-23-2008 09:43:39 PM
Troubleshooting DJB gus Onan Generators 10 01-04-2008 09:01:28 PM
Troubleshooting Question Frank Gassett Antique Engine Archives 11 04-28-2003 03:34:05 PM
