Case 500 on Steel new to the nest
this thread has 20 replies and has been viewed 2925 times
Old 05-14-2017, 08:24:00 AM
J Ware J Ware is offline
Default Case 500 on Steel new to the nest
Went to an auction yesterday that was listed in Old Abes News. The gentleman collected Case tractors. This 500 on steel,amish steel came home with me. They said the owner was a good mechanic and a good share of the tractors ran. Was told a battery and some fuel and it would start right up.
Are owners using 1 12 volt or 2 6 volts battery? Where is the easiest place to get fuel filters for the old girl?
I plan on cutting off those floppy tires.
ID:	282160   Click image for larger version
The Following 2 Users Say Thank You to J Ware For This Post:
Old 05-14-2017, 09:19:40 AM
Default Re: Case 500 on steel new to the nest
Will be fun to see how it looks with the rubber off.
I use one big 12 volt in place off two sixes for ease and economics. Have had no problems.
Get some pictures in bare feet!
Tony
Old 05-14-2017, 10:53:07 AM
I will Tony, probably be a few weeks though I need to finish up the Cletrac repower project and hear the twi cam run first but I will get too it this summer not to worry. I will also have to free up the clutch which I hope won't be to difficult. Jim
Old 05-14-2017, 12:17:12 PM
Caanderson Caanderson is offline
Napa auto parts has pretty good fuel filters for these
Old 05-15-2017, 08:09:48 PM
I just checked the serial number and it's a 1954. I did alittle investigating yesterday and found the fuel shut off is stuck on the injection pump. Any suggestions what I might try to free it up. Jim
Old 05-15-2017, 09:44:57 PM
I sent you an e-mail. You need to check the governor shut off unit. If it is stuck the plunger is probably also stuck!. I hope you have not tried to turn the engine over. You may have broken the plunger and you just kissed 8 hundred to a thousand dollars good by. send me an e-mail and include your phone number if you have not turned the engine over.
Old 05-20-2017, 11:45:42 AM
Brothers Clemens's Avatar
J ware,
I dit not notice this thread before.
You might have the same same problem that we had in the past an fixed now.
We had an lot help from friend and friendly Smokstakers.
So if we can help other Smokstakers we wil help them aswel.
Watch the next 2 pages in the next thread,
https://www.smokstak.com/forum/showthread.php?t=164233
https://www.smokstak.com/forum/showt...=164233&page=2
Greatings from Holland,
Chris,
Old 06-28-2017, 05:57:37 PM
Gotten caught up on a few things so Im taking some time to try and get the 500 started. Changing the oil, filter, and fuel filters. Replacing the battery cables with ones of proper size, a new battery. I checked out the injection pump and everything there seems all right.
My question today is, does anyone know where to get a solenoid for the autolite starter, the threads on the stud for the batt. cable is stripped. Going to try to take it apart and replace the copper stud, but if thats not possible need a plan b. Jim
Old 06-28-2017, 09:08:16 PM
halcon halcon is offline
That is not a completely new problem, I'll bet If you sit down and think about it, some of that fuel has been in that tractor tank a very long time. I like to drain the complete fuel system and use it to flush out some old transmission then send it to the recyclers then put fresh fuel in and add some 2 cycle oil if you like (not the stuff with graphite in) I think you'll find it will behave for a long time. Adding fresh fuel don't help the old stuff is still breaking down from water moisture and air.
Old 09-30-2017, 09:33:24 PM
Thought I would update you on my progress on the 500. As of my last posting I was able to replace the copper stud in the solenoid, but determined the pump was stuck so I removed it and sent it off to be checked out. Appears to have factory seals still in place, possibly never been repaired before. Some might think I'm throwing my money away but I think it will be money well spent in the long run. Hope to have it running before cold weather. Jim
The Following 3 Users Say Thank You to J Ware For This Post:
Case L on Steel Update tristan e Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 09-02-2016 06:18:36 PM
Case VA on full steel? J Ware Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 11-29-2015 10:04:43 PM
S Case steel wheels Lyle Stomp Antique Farm Tractors 0 07-19-2011 09:19:31 PM
Need steel for Case RC. carl wagner Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 06-23-2009 07:41:17 PM
case c and J.D. RA steel wheels. GregSenn Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 08-17-2005 10:39:11 PM
