Twin City FTA 21-32 serial number
this thread has 19 replies and has been viewed 791 times
Old 11-15-2018, 01:04:38 PM
Russ Hamm's Avatar
Images: 1
Default Re: Twin City FTA 21-32 serial number
My 35 doesn't have a letter, but it does have faster gearing, not the fastest near as I can tell.
The Following 3 Users Say Thank You to Russ Hamm For This Post:
Old 11-15-2018, 01:52:16 PM
Molinegb Molinegb is offline
Your Kt has KTA carb/manifold and air breather.
The Following User Says Thank You to Molinegb For This Post:
Old 11-15-2018, 03:39:08 PM
CG33 CG33 is offline
Thanks. Yes I did realize after purchasing that there are several KTA parts on the KT, as you pointed out. sounds like that is fairly common, so not sure yet if I want to hunt down original parts or just keep it as is. The magneto is a different model too. There are a few other parts missing from the KT, throttle valve rod, choke rod, radiator screen...
I have the FTA in the garage, that one seems more complete and accurate, so working on that this winter.
The Following 2 Users Say Thank You to CG33 For This Post:
Old 11-15-2018, 03:42:12 PM
I have KT 300125 as well as several KTA's.
The Following 3 Users Say Thank You to Molinegb For This Post:
Old 11-16-2018, 11:42:40 PM
Duey C Duey C is offline
I sure don't have a clue about the E on the serial but you have a couple sweet looking TC'S!
Your "modern" 21-32's rear wheels answered questions I had in my head from another thread here! Thanks for the pics!
That K is a real cutey! Dang they look good!
May I ask a favor Clay? What part number is your KT's steering wheel? I don't have a parts book for the K's and am an MTA guy.
Thanks!
The Following 3 Users Say Thank You to Duey C For This Post:
Old 11-17-2018, 01:24:45 PM
I almost got an MTA. The guy I bought these from had one of those too but I didn't realize how wide it was until I pulled my trailer up and said "that won't fit"! He had this FTA and I wanted that too. I only had enough money (and space!) For two tractors unfortunately.
Steering wheel on my KT is part number KT 521. I also have an original R739 repair parts list that has the same number.
Old 11-17-2018, 11:35:25 PM
Very cool! KT521. The MtA's is MT 3 hundred something. Ya, they're wide.
Thanks Clay! I appreciate it.
I'd fill these 4-1/2 acres with Twin City's if Maw would let me.
Like I need more to do. Yes, yes I do.
Happy jealousy about your parts book: I have a reprint R740 KT Instruction book that a friend gave me 20 some years ago. I'm glad you have that R739 to go along with the KT!
Old 11-19-2018, 12:14:44 PM
Book show FT63 axle used from 150303-154649. Ft63B used 154650-155399. MM used letter designation after serial for front axle type. S(standard) was common as well as N for single wheel E came later in 1947-8. Extendable. May have been used for axle changes earlier.
The Following 4 Users Say Thank You to Molinegb For This Post:
Old 11-19-2018, 06:43:33 PM
Thanks Molinegb. I haven't looked that closely at the axles, certainly nothing jumped out at me right away, but as I noted earlier, I have no experience with old tractors. I will take a closer look at the axle part numbers.
There is one piece that I think broke during transport, the part that attaches to the muffler, it is a cast iron piece, but part of it broke off and is probably beyond repair. The part number is FE340C. Would guess it might also be on the early MM G tractors? Anyone know of one that is available?
While I'm a long way from needing it, anyone know where I could get the decal that was used in 1935 that has "Minneapolis Moline Twin City" in red, black and white?
There is a ton of knowledge on this site, glad I signed up!!
---------- Post added at 04:43:33 PM ---------- Previous post was at 04:10:13 PM ----------
Just checked the front axle, FT63B is the number. So looks like that is normal.
Old 11-19-2018, 08:53:44 PM
Heat riser for all F GT.GTA.Gtb tough to find as is manifold. All same.
Standard twin early serial number dates Standard Tractor Guy Garden Tractors / Mowers / Scooters 11 03-13-2018 03:53:00 PM
Maytag Multimotor Twin Serial Number walkswithsticks Maytag Engine Collectibles 3 01-31-2014 11:13:43 PM
Twin odd serial number GaryH Maytag Engine Collectibles 4 09-06-2008 09:37:52 PM
21-32 twin city MM serial numbers stimulater7 Antique Farm Tractors 5 04-26-2008 10:42:23 PM
Standard twin serial number location David M. Lyon Garden Tractors / Mowers / Scooters 3 04-04-2008 08:15:02 PM
