Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
1/3 Case-Reduction Engineering Begining in Califonia
this thread has 101 replies and has been viewed 14167 times
Old 05-12-2016, 07:57:25 PM
sjkhouse sjkhouse is offline
Default 1/3 Case-Reduction Engineering Begining in Califonia
I hope to begin forming some of the boiler sheets in the next couple of weeks. I stumbled into B7100 here on smokstak , he has already been incredibly helpful.
I would like obtain a copy of Ralph Andres book , How to build a 4" Case traction engine. I have been watching Ebay for it . Any other ideas?
I am in central California , and I would like to know if there are any Reduction projects (under construction or completed ) in my area or even on the west coast.
The Following 2 Users Say Thank You to sjkhouse For This Post:
Old 05-13-2016, 08:25:04 AM
Casemaker Casemaker is offline
Default Re: 1/3 case-Reduction Engineering begining in Califonia
I can fix you up. PM sent.
The Following User Says Thank You to Casemaker For This Post:
Old 05-19-2016, 07:40:13 PM
Today I received 3 of the boiler forming dies from b7100 ,again many thanks .I am very interested in acquiring the rest of them , particularly the 2 for the throat sheet and the firebox ends . Please let me know if anyone knows where I can find them .
Casemaker has agreed to provide me a copy of Ralph Andres book, many thanks to him also . I'm going to slow down a little until I get a chance to study the book.
Old 06-04-2016, 10:25:12 PM
Reuse is the ultimate recycle , on the far right backhead die borrowed from b7100 ,next adapter to allow throat die on my too small rotary table bought at a garage sale a few years ago for $25 ,throat forming die from surplus structural connector ,foreground structural connector ready to become firebox die ,straight side cut with gas chop saw built from dead target saw that I coupled to a homelite 360 that I never liked as a chainsaw . The target was so old that it is a v belt , the 360 clutch( note hole sawed in case to allow extra space for double clutch thickness) nested into the target after turning its sprocket teeth off in lathe two brazing spots secure it and a brass washer takes out the side play . hopefully this post works as I am getting familiar with smokstak
Old 06-07-2016, 08:45:59 AM
I have heard and it appears from looking at old threads that some builders have chosen to eliminate the superheater and increase flue sizes . I would appreciate any input as to sizes and layout . Also I understand that there is a 1/2 scale that has been at some of the shows on the west coast ,that is having a commercial boiler built for it . Does anyone know about who's that is? Thanks
Old 06-07-2016, 11:45:09 AM
I believe you are hearing about a half scale that has recently had a ASME code boiler built for it. I will PM you will the owners name and phone number when I get home.
Old 06-22-2016, 09:18:28 PM
50 years ago I built a boiler in High School shop and now I am standing in almost the exact same place with the first tangible piece of my 1/3 case, the flanged , trimmed in lathe ,ready to be bored for flues , flue sheet!
ID:	256786   Click image for larger version
Name:	flue sheet.jpg
The Following User Says Thank You to sjkhouse For This Post:
Old 06-22-2016, 09:45:36 PM
Big Bird Big Bird is offline
One piece at a time..... The only way to get it done..
Remember.. The biggest hole starts with just one shovel full.
How long did you beat on it before you got to trim it down on the lathe.
The Following User Says Thank You to Big Bird For This Post:
Old 06-22-2016, 09:46:29 PM
greysteam24hp's Avatar
greysteam24hp greysteam24hp is offline
Images: 100
I just sold a 4 inch Case reduction engineering book today on eBay. I had two so decided to sell one off. There's lot of reference blueprints in that book.
The Following User Says Thank You to greysteam24hp For This Post:
Old 06-22-2016, 10:49:03 PM
chrsbrbnk chrsbrbnk is offline
what did you decide on for flue sizes and definitely skip the super heater
a couple years back I had a conversation with a guy who lived near guy who made the prints he said the super heater wasn't the greatest idea i thought Andres was gas fired so sooting would not be as much of an issue as doing wood or coal but even then you'll get more hp from larger tubes, gas flow and thermodynamics don't scale directly more like a cube root function
The Following User Says Thank You to chrsbrbnk For This Post:
Old 06-23-2016, 08:55:23 AM
I had a helper 2 days ago , we probably spent an hour with 2 rose buds. After it cooled and I got a look at it ,I realized it hadn't gotten pulled down on the die tight . Yesterday I worked by myself and finished it up . I probably spent 45 minutes and used a propane set up which I had laying around , so that probably slowed the finish off a little .
---------- Post added at 07:55:23 AM ---------- Previous post was at 07:51:57 AM ----------
I'm going to follow the layout from B7100 11 each of 1-1/4" tube no super heater
Old 06-25-2016, 12:18:10 PM
b7100 b7100 is offline
Saw your picture with your first formed part. Looks like you have a few grey hairs. You'll have a lot more by the time you get done with this project.
Old 06-25-2016, 12:31:18 PM
Was that book a" reduction engineering book" or was it a" Ralph anders book published by apple blossom " that you sold on eBay
Just wondering if it was different from the one I have.
---------- Post added at 12:31:18 PM ---------- Previous post was at 12:27:01 PM ----------
Hey b7100 did the video come thru of the case I sent you. Jeff C
Old 06-25-2016, 01:33:48 PM
No I havn't seen it. Maybe you could try posting it on the stak. To my knowledge reduction engineering doesn't have a book. He apparently purchased the the patterns from Ralph. He seems to be a nice guy but has never built one of these and has very limited knowledge as far as building one of these.
Old 06-28-2016, 10:09:01 AM
Reduction Engineering was started by Ralph Andreas....the book "How to Build a 4 inch Scale Case Steam Engine and Water Wagon" was written by Ralph Andreas. The book is not published any longer..it was published by Apple Blossom. The book is chock full of good information for building a boiler and machining out the castings. It also contains drawings as well.
Old 07-02-2016, 09:22:46 PM
Here is the "A" flanging team Santa Cruz Ca. ( At least as far as we know)
All the boiler/firebox ends are flanged .We both learned a lot and had a lot of fun. My helper on the right grew up next door to me here and has had some experience (finger prints are on the Alaska pipeline , from the very early days) Due to a missed hammer swing when the throat sheet was on the male die , we put it back in the throat die for a re do and it came through with flying colors. Looking ahead a little , I am unsure about putting my tubes in , whether or not to weld or swage . I wonder if there has ever been a process to " hot swage" by heating the tube/sheet and hitting both with a custom made tool?
Old 07-03-2016, 05:18:45 AM
Expanding the tubes is not that hard. You need a 1 1/4" tube expander. Get a real close fit on your tube holes. Read my post for tolerences. Beading requires a specially ground air chisel bit and a good quality air chisel. I put a copper ring around the bottom flue in the smokebox to make it easier to get the tubes out if you ever have to change them. If you decide to weld then it will be a lot harder when you have to retube it. Looking good. That is the hardest piece to form. How did it come out for fit around your 9 1/2" tube?
The Following User Says Thank You to b7100 For This Post:
Old 07-26-2016, 12:23:02 AM
I haven't gotten much done recently because I've been working quite a bit( mostly because I'm supporting my case habit) Neither of my mills is big enough to rotate the throat sheet on a rotary table so I'm using a boring head as a fly cutter . This mill/drill has a 3phs motor and I've cut the frequency to a little over 30htz with the vfd . I've used it for drilling but not any sustained amount of time . The household fan is for extra cooling and I have taken quite a few breaks to let the motor cool . I don't know how much heat a motor can take, I'm just going by what feels comfortable to my hand.
On another note, my son lives in Minneapolis and there are going be a couple of opportunities to visit the area coming up between now and thanksgiving . I would appreciate any input about events ( within 500 mi of Minneapolis ) where I might see 1/3 reduction case projects.
Old 08-14-2016, 10:27:57 PM
Default Re: 1/3 Case-Reduction Engineering Begining in Califonia
ID:	260309Click image for larger version
ID:	260307Click image for larger version
Here we go bending the wrapper sheet , with long time childhood friend ,Gary and Neeka our lab. After looking at previous threads and some of the set ups, I was loaded for bear with 2 20ton jacks and one 12( I had 2 more on hand but couldn't fit them on the mandrel). I couldn't find a good set up in my junk pile to make rollers , so I went with 4" galvanized pipe, welding it in, and used aerosol grease sprayed on the pipe and on the sheet. Everything went great as we started working 3 jacks it was clear one would do it . ( we used a 20 but a 12 would have done the job start to finish.
Old 08-22-2016, 03:50:06 AM
Your press is impressive.
Onan 15 JC-99R Begining Journey grif Onan Generators 24 11-18-2012 12:07:12 AM
1952 John Deere A Reduction Gear-Case Oil C. Lambert Antique Farm Tractors 1 04-07-2011 10:22:50 PM
Wisconsin AB with reduction Steam Pig Wisconsin Engines 2 09-27-2009 09:20:41 AM
Where is my deep reduction?? Class of 64 Garden Tractors / Mowers / Scooters 2 07-30-2009 11:57:32 PM
Reduction Engineering contact information??? GaarScott Steam Stationary Engines, Traction Engines, Steam Boats 3 09-17-2008 10:57:05 AM
