Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
1/3 Case-Reduction Engineering Begining in Califonia
this thread has 101 replies and has been viewed 14169 times
Old 02-16-2018, 02:03:47 PM
Guy Fay Guy Fay is offline
Default Re: 1/3 Case-Reduction Engineering Begining in Califonia
[So are the 1/3 Case patterns for sale the Reduction Engineering/Andres patterns?
Old 02-16-2018, 06:24:39 PM
chrsbrbnk chrsbrbnk is offline
thats a really good question , my understanding is the fellow with reduction eng. owns the ralph andres business , this kinda bore out by the casting crap all being around 9 inch pipe which isn't to 1/3 scale of a 1915 case 65. but there are some other weird anomaly's like the water column dosen't work right and the smoke box door hinges are in the wrong place but maybe these are the patterns from reduction or andres had a couple sets out there sorta hard to belive he would need it for run volume
Old 02-16-2018, 08:30:33 PM
b7100 b7100 is offline
My impression is that there has been some improvements in the patterns over the years. Other than the water column I had little trouble with the castings. The door hinges were in the right place. The castings were of decent quality. There were a couple castings that lacked material. There was a couple times that the book didn't jive with the print. I think there was a discrepency on the pump gears. Overall things went well. It doesn't make sense that Ralph had 2 sets of patterns. In talking to the guy from reduction engineering I got the impression that he had limited knowledge on the construction process. In working with any casting you have to take extreem care in laying things out to make dimensions fit the castings. If you don't you will have a lot of problems.
The Following User Says Thank You to b7100 For This Post:
  #64
Old 02-19-2018, 10:17:54 AM
sjkhouse sjkhouse is offline
I wonder if there has been any attempt to track where ( and how many ) 1/3 Ralph Andreas projects there are ? How many sets of castings ?
Old 02-19-2018, 01:28:10 PM
skugger skugger is offline
there is a little bit of a mystery here. Reduction Engineering was the name of the business that Andres owned and sold, and is the business name currently in use by folks in North Dakota who are selling 1/3 castings. But there is also a gentleman who lives out west who has a set of Andres castings for the 1/3 scale Case, which he is advertising for sale on EnginAds, I spoke to him on the phone over a month ago. The North Dakota folks have the drawings available, while the other gentleman has the original typed text that Andres typed that became the text for the Live Steam magazine issues and also for the book. Both sets of patterns have a pattern that produces a crankdisk with the name 'Reduction Engineering' on it. So it would seem that there were / are two sets of patterns for the 1/3 scale produced by Andres, but why? and why would one set have the rights to the drawings while the other has the book? We may never know.
The Following 2 Users Say Thank You to skugger For This Post:
  #66
Old 02-19-2018, 03:37:25 PM
Casemaker Casemaker is offline
Yes there are two sets of Andres patterns. Ralph created the first set after deciding to get out of the business, then changed his mind and created the second set of patterns which are with Reduction Engineering currently. Several years ago i spoke with Ralph and thats what he told me.
Old 02-19-2018, 04:05:35 PM
Big Bird Big Bird is offline
Didn't Ralph also design a loco and have a set of patterns and plans for that, and when did he build it?
And whatever happened to Arron Ternings 1/4 scale patterns....
Last I heard Ted best had them... but, he wasn't selling any castings at the time and possibly had put the patterns up for sale.
Old 02-19-2018, 08:16:21 PM
Ted has/had the 1/4 scale patterns for sale on engineads.
Old 02-20-2018, 09:45:31 AM
I don't find the castings " out west " on enginads . Anybody know where they are?
Old 02-20-2018, 12:20:22 PM
JohnMN JohnMN is offline
Perhaps he's referring to this pattern set:
https://www.enginads.com/classifieds...t/147043/cat/7
John
The Following 2 Users Say Thank You to JohnMN For This Post:
  #71
Old 02-24-2018, 10:25:45 AM
Yesterday I was given this piece of 24" well casing , from the same well driller that sold me a piece of 16" for $20. The 16 has 3/8 wall thicknes which I believe is what Elwin used on his case front wheels . I thought the 3/8 was going be pretty hard to cut and drill . This piece of 24 has 1/2 walls . If I can get through cutting it I am worried about scale . Will it look ok on the finished tractor? I would appreciate any input !
The Following User Says Thank You to sjkhouse For This Post:
  #72
Old 02-24-2018, 02:47:15 PM
How about a plasma arc cutter their getting pretty cheap at say harbor freight with all the extra width you could think about extension rim I am considering them on mine as it sinks like a rock in semi sandy soil
The Following 2 Users Say Thank You to chrsbrbnk For This Post:
  #73
Old 02-24-2018, 02:55:00 PM
If you're still worried about the look of the thickness of the rim you can always taper The Edge to make it look thinner but leave it full thickness where the spokes run through...
The Following 2 Users Say Thank You to Big Bird For This Post:
  #74
Old 02-24-2018, 03:41:17 PM
There are 1/2 scale back rims made out of 1/2 inch thick material....its hardly noticeable.
The Following 2 Users Say Thank You to Casemaker For This Post:
  #75
Old 02-24-2018, 04:58:55 PM
We could cut them up here are you driving or flying... carry on?
Old 02-25-2018, 09:45:03 AM
I have a Snap On plasma cutter on loan from Gary , it's supposed to be rated for 3/8 but I have had a hard time getting it to go through 1/4 mild more of body shop tool. I did have some 1/8 stainless laying around and made an ash pan for the case .Hot knife through butter thing . My local welding shop is supposed to be having some demos of expensive ones , maybe I'll show up with this! Maybe I could call the Enterprise and get Captain Kirk to tele transport, would be a great day in Minneapolis I see your having a heat wave! I have an idea to use an abrasive saw in one of my back yard set ups , I definitely like the idea of heavy duty . I will probably take on the front 16" first , there is more of it to screw up!
Old 02-25-2018, 06:58:47 PM
There are a ton if holes to dril. You have a lot of work ahead of you. I would spend some time searching for thinner pipe. Looks isn't the issue but the extra time you are going to spend drilling and machinning is. Its drilling a couple hundred holes through 5/16 or 3/8 vs 1/2". I got my pipe from an oil well supply place.They deal with large diameter used pipe. I got a 24"x 30"x3/8" for $80. There is enough left for extensions. If you can find some used pipe and sell that one for scrap you might be better off. One thing I would check is the out of roundness. I had an inch out of round. I used a hydraulkc jack to straighten it out. Still isn't very round but yiu can't tell. Had I have known it Butch has a roller. I think I could have had him roll them cheaper and had a better rounder wheel with a lot less work. One other thing to consider is the finish on the used pipe. What I used had some deep rust pits. I spent a lot of time with bondo filling them and getting an exceptable finish. I don't know how that will hold up. Plus when I drilled the holes for the spokes it disrupted the bondo in spots causing more work.
Things are looking good so far. There is a long road ahead of you. You can see how you can spend 5 years and 10,000 hours building one of these models. Most people don't understand that. Looks like a cool thing to do but you really have to have the passion, resources, and comitment to follow it through.
The Following 2 Users Say Thank You to b7100 For This Post:
  #78
Old 02-26-2018, 10:36:50 PM
Back yard wheel slicer a success ! I had a lot of doubt about this when I started putting it together . I had hoped that weight on the casters would take care of any thrust but initial try the casing took off side ways . I stuck a cross bar in the back end of the casing with a half inch bolt centered reasonably well and took out the slack with washers and a 1/2 pipe spacer. The piece of rectangular tube that /I /bolted the saw to acted like a torsion bar and kept the front of the saw a little above the casing . I put a foot switch on the end of the power cord and after a little experience I was able to dampen the chatter and brake the rotation with one hand . Once a groove was established I could let the casing self feed and probably had the casing turning 60 rpm . It took about 20 minutes to make one slice through the 3/8 .This piece of casing was nice and round which made this go really well . Just by eyeball watching the initial blade contact I would guess about an eighth out of round. The rims were within a sixteenth in width when I was done. I used less than a full abrasive blade to make 4 cuts. I think Elwin is right the drilling the 1/2 X 24 will be a problem ,but if I can get the 1/2 sliced now without to much trouble I am going to go for it and decide about that after I have a chance to build the front wheels . It will be a couple of days before I can get back to the case but I will make one attempt at the 24 as well as this went or possibly make a torch set up . I'll have to re configure the slicer but now that I have done it I can get it done pretty quick .
ID:	304181   Click image for larger version
ID:	304182   Click image for larger version
ID:	304183   Click image for larger version
Old 02-26-2018, 11:37:18 PM
awesome fixture and solution although you neighbors gotta really wonder what your doing as for the ton of holes I always pilot drill with like a 1/8 inch or .090 drill with a split point center drill first too did mine on the drill press with a arm clamped to the table so the wheel sat over the arm then just sorta manually indexed around
The Following User Says Thank You to chrsbrbnk For This Post:
  #80
Old 02-27-2018, 08:34:23 PM
Looks like you are getting more resourceful. You will surprize yourself with the things you will come up with as you progress.
Onan 15 JC-99R Begining Journey grif Onan Generators 24 11-18-2012 12:07:12 AM
1952 John Deere A Reduction Gear-Case Oil C. Lambert Antique Farm Tractors 1 04-07-2011 10:22:50 PM
Wisconsin AB with reduction Steam Pig Wisconsin Engines 2 09-27-2009 09:20:41 AM
Where is my deep reduction?? Class of 64 Garden Tractors / Mowers / Scooters 2 07-30-2009 11:57:32 PM
Reduction Engineering contact information??? GaarScott Steam Stationary Engines, Traction Engines, Steam Boats 3 09-17-2008 10:57:05 AM
