Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Model hit and miss identity
this thread has 9 replies and has been viewed 1361 times
Old 12-29-2016, 10:19:09 PM
Frank Klenk Frank Klenk is offline
Default Model hit and miss identity
Hello all, I am new here. I am an engine collector, my collection consists of model airplane engines and I just recently acquired this hit and miss model engine. First of all would anyone know what this is called and is it a model of a full scale or? I found a couple minor issues and made the repairs, leaking valves. I've watched a few videos on how these run. It seems to me the 2 gears running off the flywheel that opens the exhaust valve are timed. What is the procedure? I do plan to run this so any help is appreciated. Thanks.
ID:	271333   Click image for larger version
The Following User Says Thank You to Frank Klenk For This Post:
Old 12-29-2016, 10:37:04 PM
Junkologist's Avatar
Images: 160
Default Re: Model hit and miss identity
Your engine is known as the Odds & Ends engine. It was designed by Phil Duclos and the plans were published in Home Shop Machinist Magazine.
To time the gears properly, I usually mesh them so the exhaust valve closes just as the piston reaches top dead center at the end of the exhaust stroke. It can close a fuzz earlier, but not after TDC. Once you have it timed properly, you will find that the exhaust valve will open just before the piston reaches bottom dead center at the end of the power stroke. If the engine ran before you acquired it, the timing should be ok though.
Looks like you have a nice little model there and I'm sure you will enjoy it once you get it running.
Mike
SmokStak member #146
Old 12-30-2016, 05:42:36 PM
Thank you for the good information. The crankshaft journal bolts were very lose so I was suspicious of the timing. I think he may of lifted the crank out to check the ring. Timing was off and it is reset now.
More questions...
What oil should I put in the lubricator on the sleeve?
What fuel should I use? Is Coleman camp stove fuel okay? What oil do I mix with it?
Old 12-30-2016, 08:13:19 PM
Images: 160
Any light engine oil is fine for the lubricator. Lots of guys just run mixed fuel and don't even bother with the lubricator, but I like to give my engines all the lube they can stand. Coleman fuel (naphtha) is the perfect fuel for these models. No smell, no residue, no problems. Some guys like to mix WD40 with the fuel and others use 2 cycle oil.
Mike
Old 12-30-2016, 09:15:25 PM
Tom Jamboretz's Avatar
Tom Jamboretz Tom Jamboretz is offline
These are really nice engines. The instructions are the best for any engine I have made. I run mine regular gasoline with light oil in the oiler. I'm sure you will enjoy this one. TJ
Old 12-31-2016, 04:56:47 PM
I fueled it up and after some coaxing I got a few pops and sputters, I managed a couple short runs, the governor kicked in and the engine quit. I noticed compression was soft again. I trimmed the gasket a bit on the valve body, no change. Thinking back, the gent I acquired this from mentioned he thought it needed rings as he had run it a lot. I thought I had it licked when I resealed the valve body. So, I pulled the piston out, the top ring was broken. No scores in the liner. So, would anyone have 2 piston rings they can spare?
Old 12-31-2016, 06:35:11 PM
Here is where I get all my rings from models to 60" rings. Very nice man. TJ
http://pistonrings.net/ Otto Engine
Old 01-13-2019, 03:28:07 PM
I bought some piston rings from Bjorn Baal in Texas, he bought Frank Bowman's ring business. Rings are a perfect fit and it runs just fine! Check it out.
---------- Post added at 02:28:07 PM ---------- Previous post was at 02:21:47 PM ----------
The link does not work, how do I edit?
Old 01-13-2019, 05:23:54 PM
DOC0455 DOC0455 is offline
Here this one should work.
The Following 2 Users Say Thank You to DOC0455 For This Post:
Old 01-13-2019, 05:40:09 PM
Thanks Doc, much appreciated!
New Hit and Miss Owner JD Model E Maytag Model 92 Heelerman Smokstak Forums Meet and Greet 2 10-08-2014 02:24:28 PM
Help On Model Hit Miss Jim Alexander Machine Shop and Tool Talk 0 03-15-2014 04:31:55 PM
Billy Boy model hit & miss model engine Preston Wells Scale Model Engineering 1 03-03-2012 09:06:05 PM
lauson outboard model identity lausonman Small Air Cooled Gasoline Engines 2 06-18-2006 10:43:22 PM
The Mogul Runs! Hit & Miss,Miss,Miss, Miss,Miss Dan Bogart Antique Engine Archives 7 06-24-2003 12:10:08 AM
