Kohler Generators
1963 Kohler L600 Engine from 6.5M21 Electric Plant
this thread has 35 replies and has been viewed 2027 times
Old 11-03-2018, 04:52:18 PM
Vanman Vanman is offline
Default 1963 Kohler L600 Engine from 6.5M21 Electric Plant
A fellow Stak member spotted this and sent me the link. It seemed perfect for helping out with my other Kohler project., But it was in Modesto, Ca, around 350 miles north, so I delayed quite a while. It had been listed at $200, then dropped to $150. So I could no longer resist lol. We set out early yesterday morning and got back late last night. Overall it was a good trip, if not exhausting. It was good to get away from here and see some scenery. Stopped in one antique store and picked up some neat Unity spotlights.
The Kohler was actually at Beyer High School, and it was actually the small engine shop teacher Rich Wolfe selling it. Rich seemed like a nice guy, and it was cool to see a high school shop again. We chatted quite a bit and had a good time. He said it didn't belong to the school, but that he was going to use the proceeds to buy some hand tools for the shop.
The ad read as follows:
"Kohler 4 cylinder utility engine
Kohler four-cylinder engine from a generator used on a construction site to power lights. Engine only. Got this from a friend that was restoring it, but never finish the project. Currently needs spark plug wires, and a few other things to run. 98% complete.Please review the pictures and information plate for spec information. I need this thing gone, offers greatly excepted."
I also saved the pictures from the ad and will attach them.
Upon inspection, it was found that the water pump was seized, but I was still able to crank the engine with the belt slipping. No compression was felt, but the magneto impulse coupling was working. Since the plug wires were not connected I held the magneto stop switch down to avoid damaging the mag. Who knows how many times it has been cranked without doing that. I didn't check it for spark.
There was oil in the crankcase, fairly dark but not horrible. No water in the radiator.
The ad photos didn't show it, but there is a large taper lock pulley on the end of the crank. I don't yet know if they machined the crank to make it fit. But a taper lock normally fits a non-tapered shaft so.... We'll see.
The oil base had been broken and welded in two spots and is cracked in a third. I think it was dropped, and that may be what happened to the generator.
He said he had no actual knowledge of it's history, condition, or what may have been done in the restoration that was started but not finished, but his dad had recognized the engine as those used in light tower trailers in the '80's. I'm sure many did find their way into that service, as well as countless others, of course.
I explained that I was taking a gamble on a non running engine, and I offered 50 bucks. He countered at $60 and I accepted.
It was determined that it wouldn't fit in the truck with the muffler on it, and pipe wrenches failed to get it loose. We didn't want to break the exhaust manifold (which also has been broken and welded. But I had seen that in the ad photos).
I suggested merely pulling the manifold, and he really didn't want me to, thinking the bolts may snap off in the block. Looking at it, four bolts were not even drawn up, and only two were tight, so I said it would be super easy, and besides, I already bought it, so if I break it, I wouldn't blame him. Finally he brought some wrenches. The remaining two bolts are awkward to get to, but came out easily.
Ah ha. It had evidently sat out in the weather with the stack uncovered for quite some time. All four exhaust ports and the manifold are full of rust. Well... That explains the lack of compression.
While I was working on that, I also noticed that the thermostat housing was loose, the nuts only just started on the threads. Well... That explains the lack of coolant lol.
Nevertheless it's here now, still in the truck at this point. I'll post more as I learn more.
ID:	322035   Click image for larger version
ID:	322036   Click image for larger version
ID:	322037   Click image for larger version
The Following 2 Users Say Thank You to Vanman For This Post:
Old 11-03-2018, 04:55:58 PM
Default Re: 1963 Kohler L600 Engine from 6.5M21 Electric Plant
I forgot to mention that it had been cleaned up since the ad photos, probably with a pressure washer, as I found a couple areas still had some water present. Here's the last ad photo.
Old 11-03-2018, 06:28:50 PM
Zephyr7 Zephyr7 is offline
Its nice to see some high school shops still operating. All the schools around here have closed their shop programs. Too many worries about little Johnny chopping off his finger I suppose. The trouble is no one knows how to work on things anymore. We get interns at work that dont even know which way to turn a screwdriver or even that there is more than one kind of screw head
Bill
The Following User Says Thank You to Zephyr7 For This Post:
Old 11-04-2018, 03:03:15 PM
Yeah, we talked about people not working on things anymore, and how things are now made cheaply to suit that attitude. The focus is on first cost, not total cost of ownership, to suit the modern simple-minded, short-sighted buyer.
It's too bad too. If stuff was made to be serviceable and rebuildable, not only would it actually be a pleasure to own and use, but our economy would be much better off as well. It may have been easy to outsource manufacturing, but much less so service.
Old 11-05-2018, 01:29:07 AM
Got this beast unloaded tonight, and got a little closer look at things. The paint job is super sloppy. It looks more like the kind designed to disguise than to make a restoration look good.
They painted the exhaust manifold, and the radiator hose and clamps black, in place. Also painted the mag, it's nameplate and cap and all. Can see where the seized water pump has leaked rusty water, and can see the rust in the four exhaust ports.
Can see the thermostat housing loose.... One head bolt is missing... Wonder why...
ID:	322154   Click image for larger version
ID:	322155   Click image for larger version
ID:	322156   Click image for larger version
Old 11-05-2018, 01:34:40 AM
Here's a shot of the output pulley that has been adapted to the crank. If it runs true, this is actually pretty cool. It's about 10" diameter, and looks to use B section belts. I do hope they did not modify the crank to make it fit.
Old 11-05-2018, 09:25:33 PM
Some more investigation today. The cylinder head bolts were not tight, yet the thing was painted with them loose. The head had been removed then dropped right back on, old gasket and all. Now I know with certainty that the purpose of the paint was nothing more than deceit.
The head bolts were too long or short or mixed up, obviously put back without any care. No thermostat is present. Bummer. I was hoping to get one of those. No spark from the mag.
But, the valves and cylinders don't look too bad from the top. Some valves move, some are stuck. It just may yet turn out that this block is better than my other one. And that's what I'd really like. One of the cylinders has some light oily / rusty mixture look to it, but I'm hopeful it will clean up.
Old 11-05-2018, 11:37:51 PM
And here are some photos.
You can see that the rust doesn't look nearly as bad on top of the valves as in the ports.
The questionable rusty / oily cylinder next to a good one.
The mag painted black- sloppily all over and in place on the engine. It's not working, but hopefully it is just points / condenser.
ID:	322219   Click image for larger version
ID:	322220   Click image for larger version
Old 11-06-2018, 12:13:03 AM
Is that scale and pitting on some of those pistons and in some of the cylinders? Poor little engine must have had a rough life
Sounds like someone tried to work on it that didn’t really have enough skill to tackle the project so they gave up and Hastily slapped it back together.
Bill
Old 11-06-2018, 12:57:51 PM
Yeah, it's seen some bad times for sure, but the piston tops actually look better than in the photos. There's just a littly oily carbon deposits on them. But I haven't shown the busted and welded feet yet.
Old 11-07-2018, 01:45:33 AM
YAY! There is some good news! They did NOT mess with the crank when fitting up that pulley. The inner bore of the taper lock bushing has been machined to match the taper of the crank nose. Just to be sure I offered up the armature from the other set. Awesome.
They had assembled the bushing and pulley incorrectly though. They threaded the bolts through the holes that are supposed to be for removal, but instead they lined them up with the unthreaded holes in the bushing on the other side such that they weren't actually doing anything. And couldn't be used for removal. I had to use a puller. And of course they had to use one size larger lock washers. Just so it would look crappy. The large bolt in the center is what was holding the whole thing on and together. With it's own incorrect sized washers. Whatever. I'm just glad they left the crank alone.
Now just to hope the bottom end looks good.
ID:	322310   Click image for larger version
Old 11-07-2018, 11:00:56 AM
Innards on the electrical end don’t look too bad. Maybe you’ll luck out some on the engine too
Bill
Old 11-07-2018, 12:21:47 PM
Oh, I should have clarified- that armature is from my other set. I just slipped it on there to see that the crank taper hadn't been altered. This one is just an engine with a big pulley. I bought it to use / combine parts with the other one. That project is here:
https://www.smokstak.com/forum/showthread.php?t=178752
Old 11-07-2018, 01:30:52 PM
Ahh, that makes sense then. Im just in generator-think mode this morning
Are you planning to run this engine or just keep it as a parts unit?
Bill
Old 11-07-2018, 02:23:00 PM
My plan is to combine all of the best parts from both for the generator set. My hope is to assemble the remaining parts into a running engine, and put that big pulley back on it.
Old 11-07-2018, 05:17:21 PM
The old two makes one special
Its kinda cool that the pulley had a machined taper. Maybe someone in that shop had some skills with the metal lathe.
Bill
Old 11-08-2018, 01:57:38 AM
It's hard to say when, where or who put the pulley on there. It looks like it's been there for a really long time. For some reason that's the one part they didn't slather with paint lol.
A little more progress tonight. Pulled the cap of the mag, and it's nice and clean in there... But the coil secondary reads open circuit. Well that's a bummer.
But I also pulled the valve cover, and was pleasantly surprised. Only very little inconsequential rust there. Got six of the valves moving freely. Two of them move, but only with persuasion. But nothing is rusted solid, so it's all good. All tappets move freely.
Pulled the oil drain plug, and a very little bit of brown water came out, then an even smaller amount of goopy water / oil stuff, then lots of just plain old black oil. Not bad at all! And much, MUCH better than what was in my other one when I got it home. The reason that one needs two bearings.
Old 11-11-2018, 01:56:14 AM
Got some more disassembly and assessment done today.
Pulled the radiator, shroud, fan, water pump hand crank etc and found that, while it is bone dry inside now, it must have sat for a long time with plain water in it. The lower radiator hose and inlet to the block are chocked full of rust.
The area behind the water pump shows where it had been rusting for a long time while the water level evidently leaked down very slowly. There are "fins" of rust at each level. On the cylinder in there as well as on the pump impeller.
Preliminarily, the bores look better in this block than the other one, but damn, that's a lot of rust in that water jacket! How much iron is left?
ID:	322604   Click image for larger version
ID:	322605   Click image for larger version
ID:	322606   Click image for larger version
Old 11-11-2018, 11:16:15 AM
Looks like more scale than part in some of those pics
Is the scale loose enough to flush out? Id bet this system was open to the atmosphere with some coolant still in it. In my expierience with glycol cooling systems at work, the corrosion inhibitors seem to have corrosion enhancing properties when they get exposed to the air.
Bill
Old 11-11-2018, 01:47:36 PM
I haven't had a chance to start poking at it yet, though they look pretty solid. Not sure how I would clean out deep inside.
Got the engine proper removed from the oil base. Visually the bottom end looks pretty good, no rust or anything amiss. Quite a bit of end play, just by feel. I was hoping this one had good bearings. Time will tell. Have not yet been able to get the front pulley nut off yet, so I won't be able to remove the crank yet.
ID:	322660   Click image for larger version
Kohler 5M21 parts and questions edisondiamond Kohler Generators 16 11-07-2016 01:05:38 AM
Kohler 5M21 no output Ron Haskell Kohler Generators 16 11-27-2015 06:04:41 PM
Kohler L600 Electric Choke Luke L Kohler Generators 1 06-07-2013 01:41:55 PM
Kohler 7.5M21 need skematic/control box majoday Kohler Generators 9 09-12-2010 11:33:29 PM
Kohler L600 engine Toy-Man01 Kohler Generators 2 03-27-2010 11:54:08 PM
