Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Sniffer valve data for model gas engines
this thread has 2 replies and has been viewed 600 times
Old 11-17-2018, 03:31:25 PM
Capt...John Capt...John is offline
Question Sniffer valve data for model gas engines
I would like to try a sniffer valve for on a Model 4 cylinder Holt gas engine. Has anyone tried this & how did it work? I have plans for a sniffer valve that uses a diaphragm from a big carb. Need more information on how to do all needed attachments...ect ! Thanks in advance. Capt
Old 11-17-2018, 04:58:47 PM
Default Re: Sniffer valve data for model gas engines
I found this link on Youtube.
https://www.youtube.com/watch?v=26sWHTttV-c
Old 01-28-2019, 02:34:13 PM
Jeff Conner Jeff Conner is offline
I see this is a old post, but yes a demand regulator with bottle propane works just as well on throttle governed engines as it does with H&M engine. I have used them on 1, 2, & 4 cylinder model gas engines. In fact, I prefer propane fuel to gasoline or camp liquid fuels as it is inherently safer and has less odor, but it still sets off the CO monitor after awhile. My demand regulator was built from Jerry Howell plans using a Tecumseh gas engine carb diaphragm.
Jeff
https://www.youtube.com/watch?v=a5yUtb7baOk
Modified Model 72 Maytag Data Wanted Francis Magnetos, Ignition Coils and Spark Plugs 3 04-14-2015 01:15:09 PM
NEED sniffer valve Plans or help for Model engines CaptainJohn Scale Model Engineering 8 06-15-2012 08:07:15 AM
Briggs Model 19D Data Plate handiman38 Garden Tractors / Mowers / Scooters 0 09-02-2010 09:07:19 AM
Sleeve valve engines Monte Stock Antique Gas Engine Discussion 5 07-29-2010 06:03:24 PM
Valve in Piston Engines? JBarnes Antique Gas Engine Discussion 8 12-03-2008 12:42:38 AM
