Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Perkins Model Engine, Mixer
this thread has 8 replies and has been viewed 710 times
Old 12-24-2018, 01:25:24 PM
Tom Jamboretz's Avatar
Tom Jamboretz Tom Jamboretz is offline
Default Perkins Model Engine, Mixer
I've been working on a Perkins engine. It is the model with the horizontal hopper cooled, open crankshaft and spark plug. My problem is in the mixer. Does anyone who has worked making one have any ideas on how the needle valve assembly is adjusted. See photos. Thanks
ID:	325054   Click image for larger version
Old 12-24-2018, 03:20:15 PM
Jim White Jim White is offline
Card Sponsor
Default Re: Perkins model engine , Mixer
Merry Christmas OLD TIMER.
Old 12-24-2018, 06:30:17 PM
Right back at you and yours. TJ
Old 12-25-2018, 03:41:24 AM
JasonB JasonB is offline
That socket head screw goes into the needle and you turn that to adjust the needle then lock the position with the nut(s)
Not made mine yet but that is how I read the drawing.
The Following User Says Thank You to JasonB For This Post:
Old 12-25-2018, 12:12:10 PM
Oscar T Oscar T is offline
Merry Christmas Tom. (Wes Tischer)
Old 12-25-2018, 06:49:36 PM
Jason, Thanks for your reply, What purpose does the spring inside do? I have the engine completed and ready to go. But gasoline fills the cylinder and gets hydro -static lock -up Thanks for any help.
Old 12-26-2018, 03:09:25 AM
As it is drawn I can't see that the spring does anything. If the top of the carb was not threaded then The screw adjuster could be used to set the basic needle gap and then if running faster the needle should start to rise in the airflow and open the needle more. A bit like a Lunk bottom valve opens when it sucks in air to uncover the passage to the needle valve.
If it is sucking that much fuel in then it's open too much and the needle needs screwing down.
Old 12-28-2018, 06:18:52 PM
I see what you are saying. I'll try adjusting the needle some more. Thanks.
Old 01-01-2019, 07:30:09 PM
Default Re: Perkins Model Engine, Mixer
Well I got it running. Seems I forgot to drill the 3 holes in the bottom of the carb.
Perkins Windmill Model Engine Dan Burkart Scale Model Engineering 4 09-19-2014 07:08:19 AM
Perkins Model Engine-Info needed garryb Antique Gas Engine Discussion 1 02-21-2006 05:55:33 PM
Scale model perkins engine-Exhaust timing GarryB Antique Gas Engine Discussion 1 03-07-2005 10:47:44 PM
Model engine mixer Mac Leod Antique Engine Archives 0 08-29-2004 05:30:36 PM
Perkins mixer Bruce Sutton Antique Engine Archives 1 10-18-2003 11:34:53 PM
